Dome lights!!!???
Anyone know, where the rear hatch light switch may locate? And i don`t mean the manual switch on roof but so called door switch. Rear dome light won`t automatically light up, when i open the hatch.
Rear passanger door switches has also problems, but already found a thread that did help me.:rolleyes::wrench:
The cargo area dome light is activated by the rear doors being open, not the hatch. The light is not designed to come on with the opening of the hatch, but the rear doors.
I know, it's stupid and should have been designed otherwise, but wasn't
Um, both my dome lights come on with the opening of the hatch. I didn't change this, but can't say if the previous owner fiddled with it.
The switch is in the actually door latch itself i.e. when the tailgate pushes the hatch latch up, it switches the lights. You can probably pull the plastic paneling off at take a look around to see the actual electro-mechanical switch.
Code:
My 93 is the same.
'94 and mine works the same.... wait.... YES... Just cheked...:D
I think we might have found another that needs his switch fixed?:p
Well then where is the switch that senses the hatch is open?
I could have sworn that I read in the thread "Things that should have been factory but weren't" a few people posting up that the cargo light comming on with the hatch should have been factory but wasn't. And mine never did, maybe I'm just crazy.
Just checked my 96 and rear door lights and rear dome comes on. And yes, the switch is inside the latch itself. Would like to find a way to make all lights come on!
Yeah, my rear doors are bad too... I guess this has to do with build-up or tarnish/corrosion on the contacts due to the lack of operation.
I've seen many threads stating that there should have been a real cargo light installed from the factory - I think some countries did get one...
FWIW, on both my '97s when a front door is opened the light between the front and 2nd row seats comes on. When a rear door is opened the light behind the 2nd row seats comes on (cargo light). When I open the hatch just that cargo light comes on.
On my '94 when you open any door or rear hatch Both Dome lights come on... I don't have any door lights...
I guess there is different designs for year (91-92) (93-94 OBDI) (95-97 OBDII)???
Thank`s everyone for help, my car year model is -92. Does anyone have the same? for checking how the lights should be working, i mean by factory made, not self tuned.
My truck is the same way, none of the lights turn on with the hatch open. However, the "Door Open" indicator on the gauge cluster is lit up. :confused:
Both of the dome lights (rear and cargo) come on in my 92 when opening the hatch...
did anybody check their bulbs?
All of my dome lights work, it's just a matter of them not working with the hatch open.
I tied the front dome and rear dome together on my '96. This makes both lights come on when any doors and hatch are opened (except pass front). This keeps the alarm system from relocking the doors if the only thing you open is the hatch. Before the wire mod and when the alarm wasn't in valet mode, it would set off the stupid horn if you opened the hatch and didn't open a front door within 30 seconds. The split front/rear dome lighting circuits on the late FZJ80s was one of the more idiotic things Toyota did on these trucks. I'm still trying to figure out a way to turn off the door bottom lights so I can leave the hatch open when camping.
Mine both works well .. the only issue that I have it's when I open the tail gate, only the front dome lights up ..
My 91 is the same. :hhmm:
