The middle dome light is activated by the front doors and the cargo dome light is activated by both the rear doors and the cargo hatch. The map light is activated by an overhead switch. Is there a way to make all of them turn on at the same time, no matter what door is opened?
Other than my initial ride home with, I've never driven the 80 with the power switch off. The owner's manual doesn't say much about it. Does it just raise the shift points and hold gears longer or does it actually alter the fuel/air ratio and/or timing? I'm getting 11.5-12.5 mpg around town, but I don't know if keeping the power button on affects my mileage. I can't really tell if it alters throttle response because I have the original throttle cable, which sticks a little. I read that some people have tried to lubricate the cable, but my understanding is that the inside has a plastic sleeve that lines the cable and I would be better off replacing the entire cable.
