Doetsch Tech - which one?
Which Doetsch Tech should I use?
  • MV-12
    Votes: 0 0.0%
  • DT 3000
    Votes: 9 26.5%
  • Pre-Runner 8000
    Votes: 11 32.4%
  • Bilsteins baby!
    Votes: 14 41.2%
  • Total voters
    34
PabloCruise said:
I'm always in a hurry! But now that I reread my question I better wait unless I want some frustration...
Definitely wait...there is not really anyway to get the correct fitting shock...I just took measurements then went through Woody's shock chart on the tech page...
they are pretty cheap for the Doescht on Summit.
Summit is about the best price on any DT's, but they only order them monthly, so you may wait a bit....
Shaffer's is where I got my Bilsteins thru, best price I found at the time.
IMO, and only IMO, build your mounts to fit the shocks, particularly in the front....adjusting the ford towers higher is easy....
Well bit the bullet and ordered my shocks on tuesday, got them today. DT8000s going to run 13.5s in the front and 12.5s in the rear. Should fit OK. I may cut holes in the floor and push the shocks up through but probably not right away.
I got mine from summit, 37.50 each. If you put the shock number in the search (IE 8368) it will give you a list of a couple items that have that number, just pick the shock. The first number i put in was not going to be available until april 16th so i found another similar lenght/end type(EB1 both ends) and order it. I used 8368 and 8403s
Stew
Update
Got the right size 8000's and I like 'em :)
8333 in front w/ F250 mounts
8368 in rear w/ custom mount on backside of crossmember (spring flip - xtend wheelbase)
The 8333 is an 11 inch travel unit, the 8368 is a 12.50 inch travel shock
No trails yet, just some paved road but these w/ 4" springs are worlds better than my tired OEM stuff...
