Does this look broken?
There's no dispute that calling a real expert and getting taken care of correctly is awesome and worth the time. That doesn't change the fact that (by your number) 99.9999% of the Toyota dealerships can't help out when you are in a bind, and that sucks and I don't see the problem with complaining about it. Sometimes @cDan is on vacation. Sometimes you DO have to get to work tomorrow and can't wait to order the best. Sometimes being forced to accept mediocrity gets you to work to get paid to get more cruiser parts.
I think at one time or another we have all been in a situation where we just needed to get moving ASAP. Just make sure to redo it correctly and keep the cheap parts as spares rather than keeping the good parts as spares for replacements of the cheapies or you will be doing a field repair sooner than later.:cheers:
If you don't want to get OEM belts get Gates non-cogged belts.
Not sure if anyone told you that?
Or simply remove the idler (replace the bolt with the correct length), allows the more durable aftermarket belts to be run without the noise.
Cover is cracked if it doesn't leak no issue. ...
Agree, would run it, if/when it starts leaking, replace the cover when doing the reseal. The most likely time for it to be broken is someone being overly heavy handed during a reseal, so that job may have been recently done?
I certainly would have used OEM but I was in a tight pinch and needed to get my rig home. Will definitely redo the belts when I take care of my cracked oil pump housing.
how so .. I mean I never test that .. did you .?
Kinda. OEM belts were failing/shredding prematurely on some rigs with souped up fan clutches. Figured it might be due to increased resistance/ power transfer. Tried top of the line Gates and they are holding up better, so far. Have outlasted 2 sets of OEM belts on my rig. YRMV
