- Thread starter
- #21
I'd personally recommend a drain/fill/run/drain cycle of distilled water before I used a flush, just to ensure long-term compatibility with the Toyota SLL coolant. I'm not sure what is referred to by "reverse flush.
What's the general plan of attack for accounting for proper antifreeze content after distilled water flush? As I understand it, after a couple flushes, you dilute the coolant held in the heater cores, which largely become distilled water after the flush(es). It's a known capacity but I can't find that info right now.
Also, do folks generally subscribe to a flush on the old coolant system prior to removal and replacement of radiator/hoses/etc, or is it better to a drain, replace all parts, then run the drain & fill with distilled water on the new components?
At this point, I have every soft hose and associated clamps, radiator, coolant overflow tank, thermostat, water inlet, fan clutch, and fan clutch bracket for the job. Don't really wanna buy anymore shtuff, but any other bits I should be doing while radiator is out?
