Dodge rear axel locked up agaain!
Brownsville,Tx.
I hardly drive the dodge and tonight when I drove to the upholstery shop the same rear tire that locked up before I left to the Crawl in October took a s*** again.
I keept on hearing a lil' squicky noise like the ones that the Ujoint make for lack of lubrication.
I noticed that last week but I thought it was a ujoint.
...then the damn tire locked up in the middle of a big intersection/avenue near the house.
...since I had previously experienced this thing, I drove slowly, crossed the intersection, and parked to check it out.
it happened the same thing, passenger rear axel shaft was out about a 1/4 of an inch. Wife and kids were wondering what had heppened.
I told them, "Nothing, we just need to go slow"
..so we went slow for a few blocks and barely made it home.
Once at home, I went back to check the damn axel shaft and it was out even more. Scary because I had my wife and the boys with me but glad that it was near home and not on the road in the middle of nowhere w/ a loaded trailer in the dark.
At this point, I know the bearing is gone and there's a 90% chances that the race is whelded to the spindle. (Funny, but last Saturday I fixed the same thing on the 14 bolt of the 40. the bearing was gone and the race was still in good shape)
I have not seen it yet, but that's what happened the last time back in October when we fixed it.
We made sure to put a lot of grease in the bearing and hub and now the axelshaft locked up again.
I will take a look at this sometime next week or after thanks giving
There was plenty of grease on the bearings and it was running fine before we did anything to it.
What the hell is causing this thing?
where is the grease going? there was no sign of grease/oil leak like in the 14 bolt
Any help will be appreciated.
the differential is a dana 70.
over-tighten the bearing retainer nut?
Buy Lil' Pete ... she runs great. :cool:
:flamingo:
Better yet, buy my Dodge.... You can park it in any parking lot. I'd even put some artwork on the hood so it'd match your 40!!!
I really doubt that I could buy another truck
the wheel would spin easily if I recall.
I spoke w/ my dad earlier today and he mentioned that the diff might be low on gear oil. It might not be reaching to the hub.
Which kind of make sense. what throws me off is that is the same hub like the last time, passenger side.
gotta wait and see.
gotta wait and see.[/QUOTE]
Makes alot of sense......this wasn't the first item checked? You do understand the rear end must be full of grease, or the bearings will not get lubed.......this seems to be a trend, and why is there a penis on your hood?
JP, once you get the bearing and race replaced (you must do both!) and you get your gear lube filled back up you need to either park it on a side hill or jack each side up to make sure the gear oil gets into the hub on the other end. Once you do this you will need to re-fill the diff as some of that oil stays in the hub.
Thanks I have a better understanding of how this thing works.
I'll start next week on this project, since the truck is park in front of my house and I did not park the truck right.
i have a SRW dana 80 that needs spider gears and a speed sensor ring came out of an 01 3/4 ton ifn ya think its something you may be interested in. gears are 3.55:1
Well my dodge went to a shop last night since the weather down here never alllow me to do any work in it,
...plus I did not want to work at my house on this type of project w/ no solid stands of my property to jack up the truck. I could already see my kids running around the truck while I am trying to figure out how to fix the damn dodge.
I spoke w/ the nechanic today and it seems that the spindle in the housing is gone and so do the race,bearing and hub.
My options are to take the housing to a machine shop and rework the spindle to spects, which my dad said that's not a good option at this point.
or
...change the differential for another, the problem with this is that there's hardly any parts for that type of truck. Not long ago I went hunting/ shopping for a Dana 60 and I almost get slap by the guy in the counter for asking questions such an old part!
anyways!
I made some phone calls to some of my friends and the findings are the following:
an 89 dodge 3/4 tons and a dually dana 70.
I am not too sure if they would fit as a bolt on under my truck but I got to wait and see since the rain has not stop.
Oh and to make things even better, a rail and bolts from a joint bar broke on the Mexican side of our rail bridge. which the contractor had just finish a few weeks ago from doing the repair.
... that sucks!
..and then kowboy says that he needs therapy!
I have both a Dana 60 and 70 with 4.11 gears in the storage building, come get them.
If Roger can get the axle to Clutchee, he or his pops can bring it to Texarkana when he gets my trailer and I'll bring to the house. If you're coming up to you sister's for Christmas you can pick it up.
When is the trailer deal going down?
I am going to check this coming Saturday the 89 axel.
if it is the right one never mind, but if not, I'll get back to you all.
Thanks guys!
Hopefully the week between Christmas and New Years.
sounds great! I'll be off from work that week and I should know by then what's the deal w/ the '89 axel.
And just when was someone gonna inform me of this deal......:flipoff2:
Gotta ask how the hell is my 65 year old dad gonna get a DANA axle out of the dodge to goto Mikes truck.......???
If you have idea let me know.................
Folks gotta look out for pops since having 4 disk fused in his neck!
If yawl have ideas let me know.
