Dodge rear axel locked up agaain!
And just when was someone gonna inform me of this deal......:flipoff2:
Gotta ask how the hell is my 65 year old dad gonna get a DANA axle out of the dodge to goto Mikes truck.......???
If you have idea let me know.................
Folks gotta look out for pops since having 4 disk fused in his neck!
If yawl have ideas let me know.
NO deal is going down yet my good 'ol friend Clutchee!
neither I would want papa clutchee to lift this thing by himself.
This is my last resource.
When you needed to know :flipoff2:
I sorta figured I'd move it over. No way I'd pops do that.... even I had to hand-cuff him to the steering wheel. :eek:. I can manage a Dana rear axle purdy easy.
Done :D
JP, check criagslist..... there's got to be a few D60's or D70's between Brownsville & Houston. If you find one up this way let me know I can pick up for you if need be.
For planning purposes, it looks like pops and I meetin' in Texarkana to the 30 or 31.
Like I said, this here plan is my last resource.
I'll check tomorrow w/ my friend about the 89 axel, which I am pretty sure we can make it work.
As far as the D60 I was referring to a front one not a rear one.
..and I know Mike said he has one. At this point I am more concern about the D70 on the dodge then the D60 front for my cruiser.
I'll keep you all post it on this matter.
Well I went and got the 89 axel out my friend's dodge. It seems like it's going to work, and there's no need to be hauling anything. Thanks anyway!:clap:
The 89 axel is not a D70. It's a D60 out of a dodge 3/4 ton. it was a government truck.
I was kind of disappointed once we were comparing the Axels.:meh:
The D70 is huge compare to the 60.
I have been doing some research on the comparison of these axels and it seems like the housing is the major difference. I was hoping it was the same but not a chance.
I could move that axel by myself. I remember when I did the 14 bolt under my 40, that MO-FO is f'cking heavy Prolly like the D70.
I am kind of glad I am not doing this job at my house. it's going to be quite a task taking off the D70 and drgging it out from it's location.:grinpimp:
well, the dodge is up and running again!
The 89 axel fit under my truck just fine. it's a dana 60 w/ the same gears, 3.54, lucky me. :hillbilly:
I don't know if it's a plus but it has a locker, it runs Ok so far!:bounce::bounce2:
it took a while but the dodge is business again.
Now I have to start looking for an HD clutch.
It does not slip and it shifts fine but last trip that Loui and I did we did smell a couple of times like the clutch was burning.:mad:
the clutch is kind of hi so I don't want to take any risk next time I haul a load.
Domek,
Are you sure you need a HD clutch? Just how many HPs are you running behind the Cummins?
If you're running stock power, I think a stock organic clutch and flywheel grinding will take care of your needs.
I have a South Bend clutch (South Bend Clutch - High Performance clutches, Ford Power Stroke & Dodge Ram Truck clutch kits, feramic and ceramic disks, Kevlar pilot bearings, and heavy duty clutches for passenger/racing cars, agricultural and midsize trucks.) in my Dodge. The clutch pedal is stiffer than stock and will hold plenty of power. My truck is not stock.
Charles
