Do I need a second battery?
Money is tight, I don't have cash for all the parts and pieces needed to do it properly. I am wondering if I buy a decent jump box. I am talking about the big ones tow trucks have not the tiny ones. I am running a edge star fridge, winch, ham and CB. Do any of you out there use these instead of a second battery?
I do the jump starter over a second battery. A second battery just means you have a second place to connect the jumper cables to when your fridge kills one battery and the headlights kill the other!
Also, :worms::popcorn:
I bought one of these, works for other stuff too.
NOCO - as a brand, is no joke.
I have a waterproof 3 bank / 12amp ea. battery tender in the boat, quality built unit that was word of mouth from my uncle's boat shop 'parts & service' dept.
$150-ish for my unit, I'd buy other stuff from their product line based on in-hand how well the unit seems & the prior rep it has in the marine boat community here.
I 2nd the jump pack. I've used mine twice on my rig and once on my son's truck. Flawless performance each time. I'm buying a 2nd to have in the truck so I have a spare-spare. Considering wiring it into the 1/0 lugs in the rear of the truck so it stays charged and then I can just flip a switch to enable "jump mode". The 2nd one will be portable.
I think it actually is a bit of a joke. Check out the teardown of the Noco booster on the AvE youtube channel. Seems like it's just good marketing.
They apparently spent their engineering budget on marketing!
Brightech Scorpion is a good jump pack too.
I went a different route and got a battery box with a marine deep cycle (group 27) and a solar kit (60w). This can run power at camp and jump the main battery in a pinch. And it not in the truck full time = less weight.
Got everything used for a total of $240
If you really need a winch, none of the jump boxes is likely to get an 80 very far. For the radios and a fridge, you'll be OK if you can top it off everyday from the truck.
I bought one of these, works for other stuff too.View attachment 1412378
If you are going the jump start route, this is the only rig to buy. We've gone through numerous jump packs at our shop (including 3 Powerall's), and this is the only one that holds up. FYI it will jump off a dead diesel pickup engine too. No affiliation, but worth every penny.
My recommendation these days are a single group 31 and a jump box. I just retired my 3 year old Anti-Gravity to my wifes car and purchased a new for me. Not because it failed it still works but it did swell up a lot over the years.
Before deciding either way, i would test the alternator and make 100% sure it is charging as the factory intended. Getting a new Group 31 or similarly large size single battery (100Ah) would be a good 2nd step. Also, unless you're planning to do an extreme expedition like crossing the Sahara Desert or going to be in conflict/remote foreign countries with this vehicle, a good jump box and maybe 100w of solar with a non-hard mounted charge controller is more than enough these days. I think the whole 2nd battery concept is probably obsolete at this point.
Whatever you say. You look long enough you'll find some douche who hates on 80's saying a Unimog is what you need.
I and many others who run a trickle run these, and my uncle doesn't give a squirt about small parts margins or that stuff, esp with family (He owns the dealership, not a little one either). It's a big dealership, boats & motors move & last he wants is bad PR for some $150 charger.
The unit I have is well thought of here, is a standard with local marine boaters & nobody has had an issue. He runs it in his, and it's a ~$90-100K boat.
It has a convenience hull socket you have to drill a hole for, so there's some skin in the game - he has had these on 3 boats running (keeps a boat 2-3 yrs max).
Haters gonna hate, Youtubers gonna youtube.
I'll take my uncle's working experience over some hater in a parents' basement ;)
Local battery store has them too, and they dropped Optimas years ago - again with problematic things & negative PR.
I built this little guy a few weeks back as a backup for home and out on the road. Cost me about 130.00 bucks to build. Could have been a lot cheaper but I wanted a good deep cycle battery. I mounted a 400W inverter from harbor frieght on the top along with a small 1.5W solar panel to be used as a trickle charger when outside. I also installed an on-off switch with a 12V socket and two USB ports for misc. items. On the back I installed connector for my zamp solar panel that already has a solar controller built into it. Pretty simple. Just watch a few videos on YouTube to get a few ideas.
I take it you didn't search for the video. It's made of extremely low quality components and is poorly put together.
I had a Noco charger. Seemed well constructed and worked really well (or about as well as a charger can work). I'm just saying that looks and marketing can be deceiving. Charger stopped working after about a year. YMMV.
^^^^ - I did actually. Didn't see it in that user library.
I wasn't concerned, saw the typical Youtube thing. 20+ videos of it with semi-positive type titling, and 2-3 sour grapes.
I have the trickle charge anyhow and not the jump pack, I stand by my experience & the way my unit is liked here in the boater community.
I have that exact Anti-Gravity battery. It boosted my 12HT about 6 times while I sorted out a bad solenoid
and battery issues. Works fantastic! It sits under the seat of my wife's car when I'm not home. I check it
every 3-4 months for charge ( never needed to be recharged after 18 months ).
When using a winch on the front of your truck, just remember it takes quite a while to recharge the battery
after using the winch. So long as you give it recharge time, you will be fine.
