Late to the game on this, but @bamabrock is 100% correct -
Used a Dremel to notch out a moon shape into the trim/reflective housing directly above the Gatling shroud. I also vertically adjusted the lights all the way up to make sure I had room to cover all adjustment settings. If you don't do this, you probably will come up short and your lights will aim down too far.
Completed my retro in January, and have been meaning to give a shout out to @bamabrock , @yuselneim ,
@2000UZJ , @reznunt and many more who have contributed great input and info into this project. The results are fantastic, and as many others have already said, my favorite upgrade for the $ by far to date. The following ran me just under $500 and approx 10-15 hours:
Morimoto Mini H1 Stage III (low beam/high beam)
* 9005: Morimoto 2Stroke (DRL/high beam)
* T10/194: XB LED (White) - removed the stock shroud between low/high housing and side marker
Additionally the harness that @bamabrock mentions above made for a seamless plug and play solution to get the projector solenoids to coordinate with the high beams. Someone commented on some string that this combination of open-solenoid projector + 2Stroke firing at the same time is like unleashing the power of 1,000 suns (was that you @bamabrock ?) and indeed, it is and its amazing!
View attachment 1700962 View attachment 1700963 View attachment 1700964
