Preparing to install my Dissent Off-Road winch wiring kit to run power from rear battery into engine bay. Needed a solution to mount my Garmin Powerswitch, negative bus bar and power shut off to winch when not in use. Did a bit of Cardboard CAD work to come up with a solid mounting solution leveraging existing nuts in fender and bolt studs. This was the best layout I could come up with. Not a ton of room in this engine bay. Now that I have done the test install I think I'm set to wire everything up.
