Yea I feel like its reasonable to go months if not years with it leaking as long as you are keeping an eye on the coolant level.
That's what I'm talking about. Mine was the same...little to no adhesion to the engine side. When I began prepping the valley plate, there were spots I noticed while removing that small bead didn't seem to have much bond either. Just an observation.Actually.. I didn’t peel anything.. it all came off with the valley plate..
The best, bar-none, lubricant for coolant seals is this stuff.
MOLYKOTE® 33 Medium Extreme Low Temperature Grease
NLGI Grade 2 - Silicone-based grease with a base oil viscosity of 76 cSt at 40°C, lithium-thickened, with no solid lubricants.www.dupont.com
Primarily, it's a lubricant designed to not swell the o-rings. It's what I use to install cylinder liners in diesel engines. If you can't find some, or don't want to pay for it, then soapy water works pretty well. You generally want to avoid using petroleum-based lubricants on coolant seals due to the swelling they cause.
It kind of sucks as a lubricant for other uses, but it's amazing for coolant seals.
Looking forward to the resultsNo leaks... I guess we'll see how it holds up running and after many heat cycles. Everything below intake reinstalled... gonna try to finish up in day or two..
That’s awesome. Nice work!No leaks... I guess we'll see how it holds up running and after many heat cycles. Everything below intake reinstalled... gonna try to finish up in day or two..
If your garage was warmer, you probably wouldn't have to had to wait so long between torques, so yea, I guess if you had to do it again, it'd be nice if it was Summer!I may get some heat for this but gasket vendor recommended basically the lightest smear or razor level thin of Permatex High Temp Gray RTV on both sides of the gasket.
I don't do a lot with this kind of repair so I guess time will tell. After setting the plate down I criss cross torqued to around 5 ft-lbs, then about 45 minutes 8 ft-lbs followed by 15 at around an hour and 15 minutes. Temps in garage were like 40-45 degrees. I'll keep checking with camera if something turns up. I could do job a lot quicker next time like most state.
No surprises on start this morning... just a little extended cranked time and fired up without a stall and ran fine. No warning lights either.
Now I need to drive some to get trust in the repair.
I wondered about this detail. Lubing the entire o-ring vs just the outside surface may be a subtle but important anti-rolling step.Let's put it this way.. I don't parachute out of planes but felt like I had to psych myself up at the same level when I committed to moving forward with the plate install in the minutes ahead.
I think as long as O-rings are slightly lubed (only lubed exterior face of O-Rings) and both sides in engine and plate have some lubrication you won't have any issues with that part. I couldn't replicate in my old tube and plate rolling that O-Ring. I have to wonder if some may still had some grit in each end that gasket snagged on.
On another note.. I failed to put the rear left manifold bolt into the hole before mounting the intake. To ensure I didn't drop bolt I tied a small piece of dental floss on it in case it dropped and then just used one of those reach tools with magnet piece removed on the end to place the bolt in that hole. It took 5-10 minutes to get it in there and then tightened up with that previously mentioned 3/16 hex tool
This is where small children, with their small hands come in handy!On another note.. I failed to put the rear left manifold bolt into the hole before mounting the intake. To ensure I didn't drop bolt I tied a small piece of dental floss on it in case it dropped and then just used one of those reach tools with magnet piece removed on the end to place the bolt in that hole. It took 5-10 minutes to get it in there and then tightened up with that previously mentioned 3/16 hex tool
