DIY: Controlling DRLs with LX Mirror Fold switch, PLUS dash indicator
Very nice write up...but @Ayune the "Something is dripping" light is actually the warning light for the fuel/water separator (fuel filter) on diesel engines, thought I would let you know, other than that, nice very nice...I'm thinking on going to a 100 series...good to know that there are cool things to do
Thanks, I‘ve updated the previous posts with the correct info.
Just completed this mod on my LC. Thanks for the detailed write-up! Got stumped when splicing the DRL relay wire. DRL's wouldn't come on even though I wired everything properly. Turns out DRL's don't come on when the hand brake is engaged. :doh:
I have a 2000 LC and don’t have the 5 way connector that plugs into the mirror switch. I do have this other connector with three wires. Anyone know what this is and why I don’t have the 5 way connector?
The white connector with 3 wires in it is for the factory locker switch I think. I'll bet the mirror connector is still buried in there somewhere.
There is a very good possibility that I’m missing it. I dug around a little more and still can’t seem to find it. Here is an image of the connectors I do have (both rear windows, mirror switch, and the three wire connector potentially factory locker, and then two wire crimp sections). I would think the mirror switch would come out of this small harness but doesn’t seem like there is anything else coming out except for the cluster of white/green wires that looks to go up towards the dash.
Anyone willing to pop their switch out and see where the mirror switch is coming from?
Either I’m blind or I don’t have the connector. Took off the bottom part of the dash to get a better view and still not seeing the switch connector.
My 2007 doesn’t have it either. I don’t really need it as I will just solder to the correct set of contacts. On a 2007 I am not able to find what wire to switch to interrupt the ground.
