Divorced t-case?
Auburn Al
Ive been exploring some options for my om606 swap.
My first idea and option was just to mate up the 606 to the stock h42 and run it like that. The only draw backs to this are no overdrive and the adapters are not readily available.
Second option is to pick up a 700r4 and mate it the stock t-case and pick up a om606 Chevy adapter. Main problems with this are it would be LONG probably wouldn’t fit well in a 40, it would be quite expensive and would have to regear the axles as well.
The third option I see is to run the stock merc trans with a divorced t-case. The merc trans is much more compact than a gm autos so it might be viable to run a divorced t-case. So here’s my question is it possible to set up a land cruiser case to run as a divorced case?
Sure, anything is possibly but your big hurdle is going to be drivetrain space in the 40. Sounds like you already know that. NP200's and NP205's were commonly divorced HOWEVER they are centered output so you'd end up with a compound rear driveshaft angle. Not the end of the world according to Tom Woods (Tom Woods Custom Driveshafts) but you'll be running a rear CV shaft for sure. Along with custom mounts for the divorced case not to mention the intermediate shaft from the Mercedes trans to the transfer. Certainly not straightforward by any means and regardless, I think you're rear driveshaft might end up so short that it'd be unfeasible to drive at highway speed. Hard to say without real measurements though.
I believe many of the early custom Datsun and Toyota mini truck 4 wheel drive conversions used either the Dana 18 or 20. The Dana 18 had an offset rear output just like the land cruiser case. I don't have any idea how hard it would be to find the parts to convert a Dana 18 to a divorced setup, though.
So the merc engine and trans is about 60ish inches from the fan to the trans output. I've looked at the Dana 18 and Novak makes a divorce kit for it for around 600. Not sure on the size of if though so it might be viable but if there was anyway to divorce the the cruiser case I would much rather use the case I have rather than buying a new one. But at the end of the day I'm more concerned about it being practical and economical.
Are you planning for any hard off-road use? If not, a samurai t-case will probably work. It's compact, with right hand front and rear outputs.
How strong is the Mercedes trans? I thought I've read that they aren't super strong.
If you adapt to chevy, you should be able to use a SBC to Toyota Bell housing and then use Toyota. 3.70 gears and 33s will net a 25% overdrive.
The older 4 speed merc trannies are pretty much junk but they got their 5 speed right. The merc designation is 722.6 and they used it up until the earlier 2000s but Chrysler continued using them under their designation NAG1 they even still used in the new jeeps. Granted they have made some updates on the way but I figure they are a fairly stought tranny if they put them behind hemis in challengers.
I have thought about the Chevy bellhousing route but I'm not sure how well double adapting would work. To do this I would have to run the om606 to sbc pattern adapter and the h42 Chevy bellhousing. It might be a possibility but I'm just not sure on the double adapters.
It will be used for moderate off roading nothing too crazy but isn't the Sammy case and underdrive in hi range?
Still trying to figure this out... anybody have anymore ideas?
Just read your post and dug up this image of an np200. It looks like they have the centered and offset rear outputs.
Interesting... I've never really heard much about the np200.
On a separate note, has anybody made their own custom transmission to t-case adapter before?
np 200 is used in the late war dodge 6x6 dodge m37 and dodge power wagon and 5/4 ton military jeep truck.its heavy and it big lots of info on google
