voodu3
I always thought the fender mounted side marker lights looked cool and ditch lights would be nice to have. No offense to anyone that has them but I wasn’t crazy about how the cubes mounted on the mirrors looked. So I found some small flush mounted led flood lights Shenzhen Aurora Technology Limited
and I thought these would be perfect in the place of marker lights.
I found the location measurements for the stock marker lights on a thread here. Pic below I used this as the starting point for placement. The lights came with a rubber seal to go between the housing and the body I used this as a template for the hole. I didn’t take a picture of this. The cutout is approximately 2-3/4” wide by 1-7/8” tall. I used a drill, angle grinder and a file to make the hole. I wish I had a dremell or similar it would have been a lot easier. Once the hole was cut I ran my wires. I have an aux fuse box under my passenger seat I ran power from there to a relay and to the switch. I had a round lighted switch that I used and installed that in the round blank on the left of the steering wheel. The lights came pigtails that I connected to the relay. The relay and switch are on the drivers side I ran one power wire across the fire wall in the engine bay to get the power to the passenger side light. The hardest part was getting the nuts and washer on the backside of the lights. If you have installed a snorkel it’s the same as getting to the farthest back Mounting stud. You have to reach in the fender access hole by the firewall to get to the bolts. Drivers side is fairly easy but on the passenger side my washer tank, aux battery cables and cruise control box are in the way. I removed all of those to be able to get my arm in. Below are some pics of the install.
