distributor in 180 out
Charleston, SC
The 40 i just bought has the distributor in 180 degrees off. If I reverse the firing order on the cap it fires up. Can I run it like this (and just confuse everyone but myself?)
Why bother? Its a 1hr ordeal to bring it up TDC, pop out the dist rotate, and re-time. That way you can also check pinging, carb adjust etc.
Change it!
Do it now!
This can cause bad misfire and extend your exhaust muffler volume by at least 30%!!
Have a guess how i know................:doh:
Just run it with the plug wires moved over 180 degrees. This is much easier and if you remove the distributor, you run the risk of ruining your engine if you do not get it installed all the way so that it drives your oil pump. The engine cannot read the numbers on the distributor cap, so it could care less.
She runs alright. Backfires and sputters. I know the timing is off but I cant find my timing light so I will have to mess with it tomorrow. The guy had been messing with it for a few months and couldn't get it to fire. :frown:
Excellent idea!
I nearly crapped my pants when i changed my dizzy, put it wrong and fired the engine up.....KABOOM..... and the exhaust was nearly gone...... as written before...30% grown to the outside......:eek:
