distributer ???
Allright my 1978 fj40 has what i believe is a points ignition. It has the vaccuum advance and a little knob on the side to adjust something. I just recently acquired a canadian distributer and coil for an electronic ignition setup. How hard is tihs to fit to my engine and is it worth it?
Hello Jim,
It is worth it, hardly any maintainance neeeded.
It is a drop in swap.
You install the distributor.
Connect the dist to the igniter.
Connect the ingiter and coil wires to your ign(on) wire.
Ground the coil bracket.
And start it.
Time it.
Look into coolerman site for more info.
That sounds suspiciously like a '69/earlier or "Non-USA" vacuum advance distributer. How about a pic?
That little knob is the Octane Adjuster, it advances or retards timing by a degree or so for every revolution...and is kinda handy to have.
I own 2 distributors. My 40 is from ‘67 but my F was built in ‘73. Can anyone tell me if these are vacuum advance or retatd? Suggestions for which one is best for a 1973 F?
@Wetlandman
First picture is vacuum retard. Second one is vacuum advance.
Vacuum advance is generally regarded as much better than retard.
The question is, in what condition is the v advance dizzy? Are the internals worn, or frozen? The threaded plastic cover is missing from the end of the advancer shaft, allowing dirt to intrude.
If that second distributor is otherwise in good shape, I'm selling new NipponDenso clear plastic octane selector adjuster caps for cheap in the classifieds:
If the advancer is bad, I've also got new NipponDenso advancers that are a direct-fit replacement.
I'm also selling a recently refurbished non-US small cap vacuum advance distributor - it will drop right into your F engine. Does your carburetor have a vacuum advance port? It would be a vacuum hose nipple on the valve cover side of the carburetor, just forward of the idle mixture screw. If not, the port can be added to your carburetor. Several vendors here on MUD can set you up.
Thank you guys! I will but one of those caps. I will PM you.
well i tried to PM you but it says i reached my limit of 50 PMs. How do i get that increased? Do i need to bring @woody beer?
