Distibutor for 1970 F Engine
Stevens, PA
I see TONS of threads for 2F engines and very little for F. Or at least what I see is not clear to me. I have a 1970 FJ40 with rebuilt carb by Marks off road ported for vacuum advance already
I want a new distributor for an F. Electronic ignition, etc. The full setup
Do any of these truly work with an F because I see most say 2F or 1959-1978 which I find hard to believe.
I see a few available online:
Amazon product ASIN B073WN46BV
Be careful of the gear on the distributor. A Chevy gear and a Toyota gear are similar and will mesh but it isn't quite right and can give you problems with time. If it says for Chevy "or" Toyota I'd avoid it. The DUI you listed has the gear specific for Toyota. I've been running that one in my 74 F.5 for two years and like it.
If you're replacing a stock vacuum retard distributor and running the stock carburetor, you may have to get ported vacuum installed to run the vacuum advance distrubutor.
Here's just one thread you may want to look over. "Click Here"
Bought the JTO distributor with the electronic pick up two years ago and I performs flawlessly. I believe it is a non-USA distributor and the pick up is Pertronix if my memory is correct. $388 plus shipping.
Complete Mel's Electronic Non-USA Distributor-0 Complete Mel's Electronic Non-USA Distributor-0
Complete Mel’s Electronic Non-USA Distributor
0 out of 5
