How big is your awning? Is it one of the 270 degree ones? The aluminum mounting bar on my ARB is only 2 and 7/16" inches wide (2" between the track mounts), so I'd guess that the low rise option would work. How wide is your OVS mounting bar and mounting slots?I would imagine that most awnings need the “high rise” option. The low rise is pictured below, but it’s too short for my OVS.
none of the oem parts are reused. Dissent supplies mounting feet and new bolts/washers.I’ve got my Dissent rack on order and it should show up late October or early November.
I also just dropped off my 200 at the body shop for major body repair that includes replacing the roof panel. It’s possible, and maybe likely, that the shop will get done with the body repairs before my new rack shows up. I don’t want to install a new OEM rack just to replace it with Dissent. What do I need to have the body shop do to seal the mounting bolts? Just RTV them until the Dissent rack arrives? What OEM rack parts does the Dissent rack reuse? I need to read this thread more carefully but it doesn’t look like any of the OEM parts get reused except the captive threaded parts in the roof.
you will definitely want the roof sealed in some manner. I did not do my install, Dissent did, but if it is like other ones i have worked on, I would want to use some sort of sealed washer mounted with bolts into the factory mounts. I would cut and drill some covers and use butyl tape to keep it waterproof. Butyl tape is somewhat easy to remove.I’ve got my Dissent rack on order and it should show up late October or early November.
I would order 3 more sets of the blanks that are used in the forward middle position And run those in all 8 spots. I think there are even sets on eBay, not sure if they are factory Toyota.I’ve got my Dissent rack on order and it should show up late October or early November.
Have you received your Dissent rack yet? I've been waiting since July 26th, 2023...starting to get impatient...I’ve got my Dissent rack on order and it should show up late October or early November.
Wow that is excessive. I have only been waiting since November and I am getting impatient. Have you called? Thinking I may…Have you received your Dissent rack yet? I've been waiting since July 26th, 2023...starting to get impatient...
No. When they said Oct/Nov, I made the mistake of assuming they meant 2023...Have you received your Dissent rack yet? I've been waiting since July 26th, 2023...starting to get impatient...
I haven't called yet. I last received an email from Cole in late November. "A few more weeks"... I know that it's going to be awesome when I finally get it, but the wait is leaving me impatient. I have a front dissent bumper and had a rear bumper on my 100 series as well. All top notch goods.Wow that is excessive. I have only been waiting since November and I am getting impatient. Have you called? Thinking I may…
I heard back via email that my rack should ship in the next week or two, and they are just finishing powdercoating on mine... I can hardly wait!I haven't called yet. I last received an email from Cole in late November. "A few more weeks"... I know that it's going to be awesome when I finally get it, but the wait is leaving me impatient. I have a front dissent bumper and had a rear bumper on my 100 series as well. All top notch goods.
I was working towards the exact same setup- great product choices and will be watching with interest!I finally got my Dissent rack and it sits waitng for me to install. I also have decided (I think) to go with a Bush Company 270XT Max awning. Has anyone installed that awning on a Dissent RR? I'd like to see some pics.
I'm also still trying to figure out which side to put the awning on. I would go passenger but I also have a Fabulous Fab snorkel. I know the snorkel will clear the rack but not sure what will happen with the awning. That's why I'm hoping someone has done this awning on a Dissent rack and I can see some pics.
How about you go first and I’ll watch?I was working towards the exact same setup- great product choices and will be watching with interest!
Thanks for taking the time to document further @CanadianRockyCruiser . It looks like final instructions are still in the works for the 200 but the assembly is basically identical to the 100 series rack so you can look there for guidance.
The main difference would be the mounting feet and then the one antenna load bar in the back you pointed out which is marked by the symbol below. Here are some pictures of the feet orientation (first two facing in, last two face outwards), and you are correct the number of symbols indicates the mounting position front to back.
View attachment 3587004View attachment 3587005View attachment 3587006
