I have these notes from when I installed a trailer light breakout box on a 2009 LX570. Might be useful?
What's nuts is that since July I've had 3 failures in this one circuit. 1. Loose connector. 2. Broken splice connection 3. Missing (yes missing) Tow Tail fuse. I have no idea how the Tow Tail fuse went missing. I can only assume that my Dissent tail lights never worked. I had brake and blinkers just know tail lights. I only noticed the no tail lights when I hooked up a trailer at night in October. The first thing I did was check the fuses but I wasn't actually looking at the right fuse.Nice! Too bad no one thought to tell you to check that fuse… especially in the 3rd post30A Towing fuse is not the same as the 30 A Tow Tail fuse.
yes but it wouldn't have mattered as I thought I was checking that fuse...Nice! Too bad no one thought to tell you to check that fuse… especially in the 3rd post![]()
Could be wrong, but i think this has been gone over before. i believe the adapter is "designed" to connect back near the resonator on the USA driver's side, even though it can be clipped in at a block on the passenger side. But as you found, when clipped in on the passenger side, the wires do not match up.This thread saved me a bunch of time fixing my trailer running light issues thank you!
On top of the tow tail fuse being blown, I also managed to get a brand new lx570 specific hopkins adapter that had the batt+ and brake wires flipped, and non-functioning left hand turn.
My Dissent bumper had mounting brackets for the lights.This seemed to be the best thread to post this question...so here goes
I have built and tested my DIY pigtail wiring harness and everything works flawlessly. Thanks very much to @linuxgod for the schematic!
Butnow that it's time to actually install the lights I cannot figure out an intuitive way to mount them. Surely you guys aren't just wedging them in there. How do you secure them?
Did you order the light from Dissent when you ordered the bumper? My instructions say the blanks are replaced with the brackets if you order the combo lights.This seemed to be the best thread to post this question...so here goes
Thanks to both of you for replying. The lights were backordered when I ordered my bumper and I did not order them until they were available several months later so it sounds like I need to reach out to them for a bracket.Did you order the light from Dissent when you ordered the bumper? My instructions say the blanks are replaced with the brackets if you order the combo lights.
forum.ih8mud.com
somewhere around here I could’ve sworn I posted the part numbers for all the bits I used.@linuxgod and team, have the same bumper, really like the y splitout, but having problems finding the Female version of the adapter at #5. The male looks like Hopkins 47815 will do. Any recommendations for part numbers and sources?
