After taking a good look at the pics above now we can start on the assembly.
First you will install the linkage onto the relese lever with the supplied stainless 1"X1/4" hardware and nylon washers. All moving parts of the relese assembly must have nylon washers and must not be to tight!
There is an assortment of different thicknesses on the nylon washers supplied but the medium size ones typically work fine.
Once you have installed the section of the linkage to the lever with the nylon washers you can install the other 1/2 of the linkage. Refer to the pics above to make sure the offset is Istalled in the right position.
The slotted holes on the linkage will go on the back and should not be visible once assembled.
Use 2 of the supplied 1/4"x1" stainless bolts, nylocks and 4 s/s washers, install to where the front linkage just covers the slotted hole on the back linkage and tighten bolts. This position should work for most but the holes are slotted if more adjustment is needed.
Now you can install the latch with the supplied m6 bolts and nuts, do not tighten these at this time. Once installed you can thread one of the 1/4"X1" bolts into the latch for the linkage, then install a nylon washer, the linkage, another nylon washer and the nut. Again, all bolts where there are moving parts must have nylon washers and must not be tight!
Now install a 5/16" nylon washer on the top and bottom of the lever and insert the supplied 5/16"x4" stainless bolt with washers and nylock from the bottom of the swing arm up, you will want the nut to be on top of the swing arm. Now install the 1/4"x1" guide bolt on the bottom of the release, this will have a nylon washer on top and bottom but not between the release and the swing arm.
Now install the tension spring onto the linkage bolt closest to the hinge and hook it to the provided holes in the swing arm gussets. Once all is assembled cycle the latch and release and make sure it's working propperly and moving freely, you may want to lube the latch at this time as well. If there is any binding check and make sure nothing is too tight and back the nylocks off a bit if needed.
Now install the supplied uhmw pad onto the bottom of the swing arm with 2 supplied shims, the shims will allow you to adjust the guide pad according to the load on the swing arm. Shims may need to be added or removed at the end but 2 is a good start.
Now it's time to install the swing arm.
There are shims supplied for bottom or top of the hinge, start with 1 supplied 1" grade 8 washer on the bottom and the 2 shims on top, this will give a good starting point. You will want to put a coat of paint on the head of the hinge shaft as these come uncoated, or have them powder coated with the bumper.
Just make sure not to coat the or paint the shaft itself!
You will want to apply a thin coat of grease to the shaft as well.
Insert the aluminum hinge spacers into the seals on the hinge, now slide the swing arm into place with washer at the bottom and add shims on top to fill the gap if needed. insert the greased hinge shaft with 1" grade 8 washer to where it's just going through the top tab, hinge and into the bumper, insert the 1" lock nut from underneath and get it started on the shaft.
Once started, close the swing arm while lifting up on the arm just until the uhmw pad is setting on the bumper, do not atempt to latch it.
Be carful during these steps as the swing arm has a lot of play until the shaft is tight and it's very easy to mess up the coating on the bumper.
Now take the remaining uhmw pad shim and insert it between the pad and the bumper,
With a flat head screw driver inserted in the cutout on the bumper for the hinge nut go ahead and tighten the hinge.
Once tight open the arm and check all clearances. The uhmw pad should barely be touching the bumper pad without the tire in place. If there is too much drag you may need to add a shim on the bottom of the hinge or remove a shim on the pad.
Once you get the swing arm set up now you can start the alignment of the latch.
The best way I have found is to close the swing arm slowly, make sure the bolts on the latch and striker are barely snug and still allow movement, check for any interference between the latch and striker and adjust accordingly, now slowly push the swing arm closed until the latch clicks twice, once fully latched pull out on the swing arm as far as you can and this seams to align the latch pretty well. After you pull out gently release the lever while making sure the latch doesn't move, then tighten up the latch and striker, close the swing arm and make sure everything is latching propperly. You may need to repeat this step a few times to get it perfect.
Once everything is aligned you can install the gas strut with the supplied ball studs and strut compression tool.
First remove the clips from the strut, then install the ball studs in the bumper and swing arm,
Pop the body side of the strut onto the bumper, now take the strut tool and place it over the shaft side of the strut. Now using the swing arm to compress the strut until you can get the tool onto both ends of the strut, now pop the shaft side of the strum onto the swing arm ball stud and remove the tool, make sure the strut is fully seated on the ball studs and reinstall the clip.
With the strut in place you can now use the hinge bolt to tighten the preload on the bearings to give you the desired amount of force and assist by the strut.
One you have this dialed to your likings you will need to set the preload on the latch by adding or removing shims from the bump stop. To much preload and it will be hard to unlatch, to little and you may end up with a rattle.
The trick is to have it as loose as possible without getting any rattles when offroad. You may need to play with this a bit as everyone may like it a little different. Once you have everything where you want it make sure you don't forget to install the grease fittings and grease the hinge!
