Discontinued valve shims
I'm having some trouble sourcing new Toyota valve shims in the quantity I need. I could go after some aftermarket shims as this will potentially get me my truck back ~1 week sooner. I am in the midst of building a 1FZ-FE with all new Toyota parts (block, head, head innards). For peace of mind, I def prefer OEM, but I'm not the most patient owner and would be OK with aftermarket units if someone trustworthy could vouch for their quality.
30.50mm dia, 2.85mm thick. X qty 10 (13753-66160) ***I've got these being made by Toyota Japan, but they won't be ready until 1/20 at the earliest***
Are there any concerns mix/matching Toyota OEM valve shims with aftermarket ones? The vendor I am considering is from Australia. In my exchange with the owner, he says there should be zero concern and he's been doing this for over two decades.
www.precisionshims.com.au
Thx!
Are you sure you need 10 the same thickness?
If you're changing shims to correct valve clearance, you need to measure each existing one, and calculate required replacement thickness.
When I did them in my 1hz and 1hd-t with the head on and cams in place, almost every valve needed a different thickness shim.
Excellent question to ask. 24 valves measuring to equal the same shim size?
Gotta buy a lottery ticket.
I get half the $!!!
Did mine in September, had a few that needed the same size, but, only a few.
Looking for opinions: if starting with a new OEM head, all new OEM valves and springs (re-using the buckets) would it be better to reuse the old shims and tip the new valves as needed, or get a "kit" of all new shims? The extra cost of new shims (if better to go that route) is not a factor for this build.
What did you end up doing here? I am in the same boat (new head, new valves, springs, re-using buckets). Is there a "shim kit" for a new head?
best to measure up the sizes required and then order as needed or have them ground/linished to suit. in some cases shims can be moved around to accommodate the required thickness.
there are lots of places that sell shims so shouldnt be a problem (30.5mm dia)
