Disc Brake Steering Components
Kris
But my friends call me Kris
NE IA
Alright, I have searched, and searched, and searched! But to no avail...
I started a disc brake conversion on my early 71 40 using mini truck components - many moons ago. I followed Guppies thread (Click) for fitting the birf, etc and that all is in good order.
My issue starts with the steering components. I have a mini truck power steering box mounted in approximately the stock location. My drag link and relay rod land where I would expect them to. I have the tie rod shim so I can use Fj40 TRE's. But the Tie Rod bar is too long if I use the one off the 40, and too short if I use the one from mini truck. It's like I need one in between. I have measured the tie rods from the other three drum brake axles I have around and they all match. I have no issue buying and welding up a tie rod, but no one sells a threaded insert for a 21mm - only the 23mm FJ80 ends - which I don't want to ream for.
The only combination I have been able to make work is a super janky and mixes and matches tapers, wrong length ends and SUPER not safe, but let me move the rig around with out major toe-in/out issues.
So WTF. Can anyone help? Could someone measure the length of their tie rod from a 60?
I guess there must not be many disc brake swaps on here after all. Lol.
Can someone go and measure their tie rod tube for me?
I'll try to get a measurement for you tonight if I remember. I had a similar issue when I altered a drag link for p/s. I cut the link on the right hand thread end, then tapped it to 17mm. Then cut a slot on the end for the adjustment sleeve, like stk. You could do the same with a 21mm right hand tap and proper drill bit.
4plus sells weld in 21mm and 23mm inserts. And fyi the mini truck arm is the large taper for 80 series, 60, etc. Prob being you will have to use a 60 end on the pass side to get to a relay rod. 80 never had a provision for a relay rod . Search 60 steering box conversion and you will find your answers
For my '71 FJ40 mini-truck conversion, the tie rod is 42-1/2" long and 1" OD. It's the mini-truck tie rod. I fabricated my own tapered shims.
Thanks everyone for your input thus far.
I don't want to ream my ends for 80 rods because A: I already have new 40 rods; B: I don't want to buy the ream; C: Mini truck ends don't really have enough meat to be reamed.
@tornadoalleycruiser I cannot find any weld inserts on 4Plus's website - or anywhere.
Thank you @4Cruisers & @pb4ugo for those measurements. I'll compare that to what I have.
I did find this thread that mentions cutting the tie rod and tapping a little deeper. I think I like this idea best. Thanks for the advise as well @pb4ugo.
I'll go buy a M21x1.5 Tap and try to document the process a bit.
From a post, i saved the picture. worth a call, some of the smaller vendors are excellent metal/fab masters but not the best webmasters.
@Kris "I don't want to ream my ends for 80 rods because A: I already have new 40 rods; B: I don't want to buy the ream; C: Mini truck ends don't really have enough meat to be reamed. "
Just to educate you.
40 series, smaller taper tie rod ends. 40 specific Steering arm in small knuckle pattern or large knuckle pattern depending on year.
Solid Axle Mini truck (1979-1985) 60, 62 (1983-1989), 70, 75, 79, 80 (1990-1997) series all had larger knuckle pattern and taper (same) on the steering knuckles. Which would require a shim if using FJ-40 tie rod ends. 80 knuckles cannot be used for a disk conversion without extensive fab skills. the Tie rods are a common use on knuckle conversions and "HySteer"
That being said.. there would be NO reason to ream a mini-truck steering arm as it is already the large taper that would fit an 80 or a 60 tie rod end.
My advice for simplicity. if your relay rod is fine and you are set on using the 40 new ends you already have on a shorter tie rod.. AND you are set on using the "shim" in the steering arm then,
Give Dave a call at 4plus. explain your situation, and get the weld in inserts. would be a 5 min fix with a welder. I say 5 min cause it will take 4 to cool enough to touch. I'll bet it will be $ and time ahead than trying to find the correct tap.
Food for thought, i believe he built the shims that were sold by a few vendors years ago. They were a solid machined piece and not the starter bushing fix.
@tornadoalleycruiser That is all VERY good info - Thanks!
I did come across that top post, but for some reason that picture doesn't ring a bell - maybe I was on my phone. But I had not come across the second one at all. That does seem like it would be a pretty good solution. I'll contact them and see what they say.
I do currently have the solid shim from Kurt with my 40 ends. I'm trying to *somewhat* simplify what vehicle parts come from. Especially since this will probably be more of a cruiser (get it? heh) and doubtfully will see any real off roading. So I don't see much benefit from 80 series ends.
So to try and further summarize tie rod ends:
FJ40 - M21x1.5 thread - Small Taper - Relay rod provision
FJ60 - M21x1.5 thread - Large Taper - Relay rod provision
Fj80 - M23x1.5 thread - Large Taper - NO Relay rod provision
Mini Truck - M21x1.5 thread - Large Taper - Relay rod provision
Tie Rod Tubes:
Fj40 - 42 3/8"
FJ60 - 44 1/2"
FJ80 - ????
Mini Truck - 39"
Thanks everyone!
I think 60 is 23 mm tie rod 21mm relay rod.
So the 60 relay rod inserts should work with a 40 tie rod.
I've probably forgotten a lot over the years. I know mine is a mish mash of what I had in the garage which is 23mm tie rod and 21mm relay rod. I think 40 is 21mm tie rod and 17mm relay rod? You'll get this. Call Dave explain what your doing and it will all come together. Your initial issue was tie rod and 40 ends. So pretty sure what you need is 21mm inserts for dom tube.
If I had known then what I know now it would have been much easier than shortening a relay rod on my truck. I'll prob redo my setup with Dave's inserts later anyway. I'm using jam nuts which have a tendency to come loose without a tack weld.
I updated my post above to include the tube lengths.
Yes, FJ40 Relay Rod has a 17mm thread. Because I chose to use an early mini truck p/s box vs a FJ60 (cross over) box I can continue to use the relay rod, drag link and center arm.
Just to circle back with some kind of resolution. I ended up cutting 3/4" off the right hand thread side of the tie rod and running a tap to the same depth. Thankfully I only needed about 1/2" more thread, because that's all the deeper the tap would go before having to drill the ID of the tube.
I also hacked up an old tie rod to make a thread chaser after I cut the tube. This guaranteed that I didn't cross thread the tap in.
Thanks again everyone for you help!
