disc brake conversion hiccups
midwest (iowa)
I know there are thousands of disc brake conversion posts, so I apologize if this has been covered. I wasnt able to find help on FAQ I went ahead and swapped out my front drum brakes for disc (71 fj40) New calipers, discs, rubber lines and a new master cylinder off of a 91 toyota pickup. I have new pads, and all good lines running to both calipers. The problem........each time I use the brakes, they stick a little and after ten stops they are stuck to the point that I barely have enough power to continue driving. If i loosen the bleeder on either caliper, driver or passenger side, the pressure is released and the brakes relax (release back to normal). then I start the process over. There has to be an explanation!
Did you remove the 10lb residual pressure valve in the front circuit of the master?
Could be the push rod between the booster and master is adjusted a hair too long.
Push rod too beaucoup.
I did not remove residual pressure valve. Never knew anything about it. Details???
It’s a little disc under the large hex cap that your front brake line attaches to.
But you said you installed a different master cylinder.
Push your pedal until you lock the brakes tight, then get out and loosen the nuts that attach the master cylinder to the brake booster. If the brakes release it’s the rod. If not check for that disc.
I’d missed that you put in a new master. The new master should have the 2 lb residual valve for disc brakes (if the pickup had disc brakes in the front).
When I swapped Masters around, the rod was too long. The brakes worked great until I’d driven a few blocks... then the brakes would clamp down till the 300 hp SBC wouldn’t move it. After loosening the master bolts, the brakes would release... and then we were back in business.
When I got disc brakes on mine, I had a provisioning valve added. This one: Adjustable Brake Proportioning Valve for Toyota Brake Lines - Fits FJ40
Could that be your problem? Per Racer's website:
If you have a pre-9/75 FJ40 with full drum brakes, and you are doing a front disc conversion, then you need to add a proportioning valve to avoid rear brake lock-up.
Wait, hold everything. I did install a proportioning valve. I was told that with the new master cylinder off of a 91 pick up Toyota, I wouldn’t need it so I went ahead And adjusted it all the way open. How do I properly adjust the proportioning valve?
push rod is out of adjustment. 90% chance you don't need a proportioning valve. If you did it would be
more a situation where the fronts locked up before the rear, or vise versa, when braking hard.
Inside the master , under the fluid cup, are two ports . One feeds the master cylinder so there's fluid to apply to the system.
The other is a relief port than lets fluid back when the pedal is retracted. When you release the pedal, fluid from the system
travels back into the cup thus depressurizing the lines. If the pedal doesn't retract past the port fluid never leaves the system,
building more pressure with each stroke. I did install one new master in thirty years that was defective . Having that same issue,
I removed the cup and saw the relief port had not been bored. A dimple was there, where the port should be. Probably a case of a broken bit in a CNC cycle at the factory. I disassembled the master, drilled the port and everything worked fine.
Shorten the pushrod. If you're out of threads, cut a little
Hey Dave,
How you doing,
I just did front and rear disc conversion on my fj40 (using city racer booster and fzj80 MC ) and I have exactly the same problem. My brakes randomly stick so bad I cannot even move. I also have a built 5.7 vortec.
I don’t have portioning valve.
How do you adjust the rod properly?
I just went through the same issues only with the front disc brake conversion. Thanks to the guys on this site, their advice was correct, I pulled off the master cylinder and pulled out the little push rod ground off about 1/8 to 3/16 of an inch of the end of it and put it back together and it works perfect
Hey Dave,
How you doing,
Basically, if you have to compress the pushrod to remove or install the pin at the pedal, the rod is too long. I like to have some play
so there's an 1/8' or so room to depress the pedal before it lines up with the fork on the push rod. Also , make sure you have the return spring on the pedal
