Disassembling electrical connections
Oregon
Does anyone have any tips on taking apart these factory electrical connections. This one in particular is the female portion of the connection for the factory carburetor.
I started taking it apart, but could not find any retaining clips for full removal from the green plastic.
@Oregon LC
Here is a picture from @Coolerman 's website which show the tab that "keeps" the terminal in place. In the video above, you are bending this tab down to enable the terminal to slide out of the connector. It takes some effort, particularly finding a thin enough tool to fit into the connector.
2019331
Up till quite recently I had found the best tool for removing the female 6.3mm terminals used in FJ40 connectors to be the metal side support strips salvaged from old wiper blades. They are usually stainless steel and very stiff. They come in varying widths and thicknesses depending on the wiper. I had collected several of them, cut them to fit my hands, shaped the ends to a bit of a point to make insertion easier and they work great.
For the male 6.3mm connectors it depends on the style of male connector housing. For the white connectors I use a 5/32 chain saw sharpening file. The end that you drive a handle on is the prefect size to reach in and compress the tab. I have two of these and one is ground down just a bit to fit into the smaller connectors better.
The green male connectors, are built differently and requires the thickest wiper blade tool I have. Sometimes I have to stack two tools on top of each other to get the thicker tabs compressed.
One tip that will save you many cuss words: Push the wire in from the back and hold it in when compressing the tab. If you don't do this find that the tab compresses down except for the very end of it. Then when you try to pull the terminal out the tab end will fold over making it almost impossible to get it out. Also leave the tool inserted as you pull the terminal out the back. If you don't the tab can spring back up and fold over.
A MUD member turned me on to this tool kit from OTC: OTC Terminal Tool Removal Kit
It has a tool for easily removing the tiny terminals for the Metri-Pack 180 series connectors I use.
That's what I discovered also, old wiper blade inserts.
