Disadvantages of buying a Lexus LX570 over a 200 Series
No, just overall look is more soccer momish. AHC disconnects too much feeling from the road (some ghys like that, others want feedback). The Lexus looks/feels more sophisticated inside/out. There are board members who have scratched theirs up proudly. I don't think I could get myself to do that on an LX570 (mind you I have on my LX470). Maybe its more coats of paint/gloss. But KO2s with RW wheels, arb bumpers, sliders, etc look a bit comical on LX. Both are great machines and ahc on LX is very admirable esp from on road perspective with LT tires. If I wasn't looking for an electric motor (microbus/rivian) it would have been my 2nd car.
AHC doesn’t affect the ride. You can only be in low under 7mph and in high under 18mph. Effectively, low is for getting in and out, high is for low speed off-roading. All driving is in normal. The dynamic suspension lets you pick how much you want to feel the road.
To 99% of people a LC looks like a big Toyota suv, the LX570 looks like a big Lexus suv. To most people, without modification, they both look like soccer mom mall crawlers. They have no idea how capable and special they are.
My 2 cents:
My LX used 87 its entire life, no hiccups. I verified the timing was being adjusted slightly by the ECU. It was only driven 60,000 miles, but that's a difference of thousands of dollars. No disrespect to those who want to pay the premium for premium, that's just my experience.
I am in the market for a 200 series and like many, have gone back in for regarding LC vs LX. Initially I was attracted to the LC for all the typical reason,
Production numbers
styling.
standard suspension, simpler
upon some research, my opinion changed and honestly am more interested in the LX for a number of reasons
AHC suspension, as its actually pretty robust.
More clean vehicles available as it is better value
I am not going to be rock crawling, or towing larger loads so the AHC actually makes more senses as it can handle 100 percent of my use and actually be adjusted to to provide lift.
I may be able to get an extra inch or two out of a traditional suspension in the LC, but for how much i would have to spend and potentially getting a more harsh on road ride, I am not sure if a LC would be the right choice for me
with the LC, i could see doing the following
Suspension $3000
Tires $1000
wheels maybe $1000
Bumpers $2000
maintenance $2000
The higher buy in price plus 3000 grand for suspension is a lot to put into something that I really wouldn't be able to take advantage of. I would rather put that into maintenance or shooting stuff.
I don't think anybody could go wrong with either one, just pick which one makes more sense for you
Little more than year ago I made this decision used LC or used LX. My decisions came down to following.
Suspension I can change or modify in future.
Did not care for look of Lexus nor did I want Lexus badge. Most people just ignore my LC or think its highlander or sequoia.
Low grade gas.
Seems to be larger aftermarket for LC stuff. Not that it currently matters still all stock and will be for quite some time.
Less electronics to have to worry about.
Concerns since purchase
Quality Dealer support for general service and repair. I am currently doing all my own maintenance with just trip to Tire Shop for 3 year alignment plan. She pulled to right when I got her.
I'd like to challenge this notion as it's a common perception. Actually a misconception, because when it comes to lift clearance, AHC has the advantage.
Consider that on an LC with static suspension, max lift is constrained by the need to maintain droop travel, manageable suspension geometry (UCAs), and CV angles (diff drop). This puts max suspension lift somewhere in the realm of 3". Even with all the (fixings), perhaps 3.5", but much above that, stability and drivability goes out the door.
Then consider that 3" static lift, isn't really 3" once laden with off-roading and overlanding gear. Likely much closer to 2.5" at that point.
AHC stock, can already provide that kind of clearance. AHC is also constant height lift, regardless of load, so you'll never see less than spec'd clearance when geared up.
Now let's talk about modding AHC. With a 10mm wrench and 10 minutes, one can apply much more lift than you'll typically see in any modded LC. Basic sensor lifts can increase reference AHC height by ~2". That adds to every position listed above by ~2". That puts AHC lifts in a range that you just won't see in an LC.
As an aside, some LX owners complain that AHC high mode will drop at speed. That's not completely true. Using low-range is the trick. AHC will keep overall ride height 1"-2" above normal stock when used like this. And will dynamically adjust for speed which is a good thing I find when running for example desert washes. It raises as I slow down for obstacles, and settles down for higher speeds as things flatten out. Allowing for stability or clearance as needed. Having things super jacked up running at high speed is not particularly helpful. If one wants more lift and compression travel, do the sensor lift, at which AHC now runs 2"-4" higher than stock ride height. AHC also dynamically adjusts damping, which will firm up either manually via "sport", or as it detects large-amplitude suspension motions.
Nothing of value to add that hasn’t already been mentioned, but check out this modified LX I saw on IG a few weeks back. Some of the comments on this thread regarding the grill design are warranted; however, I think when built right (and tastefully), these trucks look great:
That LX looks GOOD with the bumper done. Those lights @.@
One more photo from this build. Tolerances between the bumper fascia and ARB look tight:
And a newer gen LX with a Sahara - I found this on Mud awhile back:
