Diode Isolated Door Locks
Huntingdon, TN
Million dollar question. In this 91 LC (3fe 212k miles) - while wiring remote door locks, tapping into the lock and unlock wires at the drivers door harness - the remote locks JUST WORK. I'm reading all this crap about there being 3 wires (2 being unlock) and the unlock wires have to be Diode Isolated. If this is the case, where is this Blue/Orange wire that has to be diode isolated along with the other (blue/yellow) unlock wire????? And why is the remote locking system working perfectly while tapped into the door switch harness (only plugging 2 wires, and no diode isolation). This is F'ing confusing :confused:
Million dollar question. In this 91 LC (3fe 212k miles) - while wiring remote door locks, tapping into the lock and unlock wires at the drivers door harness - the remote locks JUST WORK. I'm reading all this **** about there being 3 wires (2 being unlock) and the unlock wires have to be Diode Isolated. If this is the case, where is this Blue/Orange wire that has to be diode isolated along with the other (blue/yellow) unlock wire????? And why is the remote locking system working perfectly while tapped into the door switch harness (only plugging 2 wires, and no diode isolation). This is F'ing confusing :confused:
I wish I remembered enough to help you....I installed an alarm w/ auto start in my '91 about 8 years ago. The only thing I remember not being able to figure out was the lock or unlock (don't remember which one). I ended up taking it to an installer and they easily figured it out. I believe a diode was involved.
Check my sig. The DIY Alarm thread has info on my install, it may not directly correlate, but might help you understand how to wire the diodes.
It's in the same general area/harness. I just intalled diodes on both unlock wires to prevent any funny current flows...has worked fine for a couple of months now.
Check out www.the12volt.com on top of Firetruck's excellent writeup.
