Dimensional pattern for factory soft top frame?
Best I can do at the moment, unless you have a more specific request.
Wow! That's 'zactly what I needed! Thanks!
What is the diameter of the main hoop tubes? Are the additional pieces the same diameter?
Oh, and do you have a side view and dimensions of the flat filler piece behind the door?
Yes, the stamped sheetmetal piece that fills in behind the door. It's obvious the leading edge fits the door edge, but are the door edges the same for the soft doors as well as the hard doors? And how wide is the piece, front to rear? How does the top vertical edge attach to it?
Whew, the more I think about it, the more questions I have.
Interesting the tubing diameter is in inches. I wudda thought it would be metric tubing.
Thanks again for the help.
Hard doors and soft doors work the same with hard tops and the soft top bows.
3.5 inch at the upper part and 2.5 inch at the lower part, not including the fabric retaining channel, which is half inch.
Top vertical edge of what attached to what?
Hey Brian, Did you buy a soft top or just looking?
B.T.W., ED's muffler fixed my exhaust flange for 30 bucks. Welded a whole new flange on (about 6 inch piece)
That is excellent, I am trying to piece my hacked soft top bows back into shape this will defentily help.
Another question, is there a 2nd smaller peg on the bottom of the door surrounds? I have a large hole for the 1in tube and then a smaller one off to the side in my rear door post, is this hole used?
I wouldn't mind having a soft top frame. I could run a family top on it during the summer when I want. And a soft top would allow me to take the hard top off earlier in the year, and leave it on latter, since the soft top is easier to put on and off. Right now, though, I'm just kicking ideas around. I know the Paki's make tops and frames, but geez, they really need to do something about their slow delivery.
Told ya that whole end would have to be whacked and replaced. Surprised you got away that cheap fom Ed's. They are spendy.
Trick
I showed him some plumbers crack, I think he's a bit fruity ya know!
Just kidding, He's worked with me in the past on prices. I guess he isn't so cold blooded.
