Dim Instrument Cluster
Tampa, FL
I've replaced all the bulbs in my instrument cluster with the OEM bulbs, but it's still tough to see gauges at night. I don't remember these clusters being too bright when I owned a couple of 40's back in the 1970's and I'm sure the LED lights in he newer stuff I drive, make the old ones seem even worse. Has anyone come up with any upgrades or bulb substitutions to improve this issue?
I have used these before and they work great
Just replace the bulbs.
Stevepipeman,
When you do the conversion can you post up some before and after pictures?
I went to the website, they have lots of options. I will be curious what you go with.
FWIW: my gauge cluster above:
2 of these for the cluster illumination:
194 LED Bulb - 6 SMD LED Tower - Miniature Wedge Retrofit
3 of these for the turn signal & high beam illumination:
194 LED Bulb - 1 SMD LED - Miniature Wedge Retrofit - Cool White
that's pretty impressive.
I will say, I put HVAC aluminum foil tape on the vertical section of the interior metal shell to see if it would help throwing the light around better.....OH, me likes!
Which LED for the light above the pulls? You told me before i forget lol @GA Architect
Be glad to. I should have them by 1st of next week.
Here's what what (2) BA9S-BHP5 (blue) LED Bulbs did for my 40. I don't have a comparison of the originals, but I promise you the leds are significantly brighter. The picture sucks, but I will admit that the orange needles on the fuel, amp, oil and temp are not illuminating as well as I'd like, but the speedo is great. I chose blue because of the clarity in Acura. I wonder if a white light would contrast them better. Obviously, the modern needles tend to absorb light where the old type don't.
I got them from, superbrightleds.com @ $3.95 ea. if you're interested,
Good luck
@GA Architect went with cool white, @Stevepipeman went with blue. What version did you use for the instrument panel? They offer it in 5000k, 4000k and 2500K....cool, natural, warm. Or is that Blue, I can't really tell. Thanks.
I think I used the cool white. Just use the links above. I hate blue lights. They scatter at night and I can't see them crisply ever since having laser eye surgery. Some guys open the cluster and cut out or drill holes in the light shields to let more light in. I just swapped the bulbs. It's a 20 minute job. Hardest part is removing the speedometer cable.
