I have learned a lot from this thread. Thank you crusty.
Same bearing separator I use....and I also tuned mine just for those same situations
That ring and pinion is trash
Not sure where all you have solicited Opinions...but from your original post, I did not find the responses 'conflicting'.
looking for fornt diff help. 1997 lexus lx 450
so I have recently purchased a lexus lx 450 with lockers. the front differential made some very audible howling sounds so I started to investigate and found a very lose pinion. Today I pulled the diff out, tightened the pinion a bit and took a pattern. attached are photos of the pattern and the...forum.ih8mud.com
IMO...you have a worn gear set and it is going to be difficult for us to see enough pattern to determine a bias and give you any meaningful direction.
For what its worth...if you are going to use the worn set....I would be inclined to go with the (Pinion depth shim: 0.0725
Backlash:0.007 ) set up.
It is up to you to decide if you want/need to run the worn gear set for awhile or order new, set them up and be done with it.
If you use the vehicle infrequently....you can probably get away with the current gears, but contact is going be less than ideal between the gears, just be aware.
True, but used gear patterns is not the place to learn
If it isn't to much to ask Id like to hear how you discerned these gears are trash. I have my own opinion of what makes them garbage but it be a good learning tool for myself and anyone else who stumbles onto this thread to hear your play by play I think.
I am going to guess, that when you did changes and nothing changed in the right direction, and like I said you are just chasing your tail, and no shims are going to revive the lash that is needed, for a proper setting
Not really sure were you are coming from here. I spent the time moving the pinion around to see if I could get some sort of an okay pattern out of these gears. It's been determined the gear set isnt going to make an okay pattern so the next step is new gears...seams pretty linear to me. Not much of a going in circles situation at all. Step one determine if what I had was salvageable if not move onto step 2....
Yes, time to move on to Step #2 (new gear set). You've made a good effort to see whether or not an acceptable pattern could be had. Used gears (especially those we know have appreciable wear) are difficult to set up anyway. In your case the drive side is so badly worn that I am only 'considering' the pattern there...but actually judging the ring/pinion gear relationship by the coast side pattern. That is why I said I think the best was .0725 @ .007 backlash. But even that was far from ideal.
Another thing when checking patterns on used gear sets is the importance of introducing some resisting force before checking the pattern. With new gears..not much is needed, you can hold the pinion and turn the ring gear. With used/worn gears you might need 30-40 lb. ft. of pressure. In which case I will jam a piece of wood against the ring gear and turn the pinion.
It appears there is a lot of wear on the drive side teeth biased toward the top land. You might also check to see if the pinion and ring gear have matching 'set numbers'. Someone might have put a ring gear in there...not from a matched set. In any case....I don't see what you have now as being a viable gear set if you want reliability. I think you know that as well.
Going to be much easier to start with new.
A little reading (for a primer)...that involves a Dana 60, but the principles are sound and apply to setting up any differential:
3rd...the ring gear bolts were standard...not metric.
and what do you make of those ring gear bolts? regardless I ordered new bolts with the new ring and pinion just because I didn't want to run the risk of the bolts I pulled out of this differential not being the same as what the nitro ring gear requires
I'm just curious about what was done to this differential.
