Differential pattern rabbit hole.
Calgary Alberta Canada
Ive been working on the front differential from a lexus lx450. I knew getting into it that these gears were likely going to be hard to set up. when I received allot of various o-pinions on weather or not the gear set I had was useable I decided it was best to at least try to set them up and see for myself. Thus far I have received multiple conflicting o-pinions on the patters I have taken. at no point in this process has any one single persons o-pinion lined up with the next. I was just about to order a new ring and pinion but figured I would ask the internet one more time and get some more....o-pinions
here is the pattern I started with
Pinion depth shim: of 0.0752 (this was the original pinion depth shim)
Backlash: 0.005
Not sure where all you have solicited Opinions...but from your original post, I did not find the responses 'conflicting'.
IMO...you have a worn gear set and it is going to be difficult for us to see enough pattern to determine a bias and give you any meaningful direction.
For what its worth...if you are going to use the worn set....I would be inclined to go with the (Pinion depth shim: 0.0725
Backlash:0.007 ) set up.
It is up to you to decide if you want/need to run the worn gear set for awhile or order new, set them up and be done with it.
If you use the vehicle infrequently....you can probably get away with the current gears, but contact is going be less than ideal between the gears, just be aware.
You are making this waaay more difficult than it needs to be. ;)
First, yeah, used gears are going to be hard to get a good pattern imprint -- BUT you really need to get some resistance on the pinion or carrier as you turn it. This will help get a more distinguishable pattern.
Second, just go with the shim that was in your carrier. If you knew what the old gears had that would be helpful but from my experience the shim is correlated more to the case than the gears (not always the case with new ratios).
Third, make sure you get an accurate backlash measurement across several teeth to the specs called for.
Finally :beer:
I appreciate the advice you have given me thus far. This more than anything is a learning experience. To be honest I am not sure how frequently I will use this vehicle. I can tell you that unlessI feel confident in a pattern I wont run it. I am leaning very hard towards purchasing new gears. All in all this is a learning experience and I am willing to try 100 more set ups if i have to just so I can really understand differential gear wear and differential set ups.
Damn fine attitude. You'll get there...I am confident. Strongly recommend a new gear set.
I appreciate that. I really value the knowledge that there is to gain from this. Im curious to see what responses this post gets. my gut feeling at this point is that I wont get a "good pattern" out of these gears. But will I get a good enough pattern to put these gears back into service? I really do not know. A good friend of mine made a comment about all this work the other day I got a kick out of. He said "perfect is the enemy of good sometimes" and I see his point. but what I have noticed from all the information I've gathered online and all the opinions I've received is that this all seams quite subjective and peoples attitudes towards gear set ups seam to be eaither "its fine just run it with good pre load and back lash" or o god thrown those gears in the garbage and start from scratch.
Ask Ken at Toyota Gear Install Harrop
He is the authority on gear setup for these. Doesn't matter much on opinion of everyone else. He has thousands of these under his belt, as he does it for a living, and he's damn good at it.
Look up the one for Kittery Point, Maine and read the bio he did on it. You'll get a lot of GREAT info!
