Differential drop necessary?
Hello folks
I have a 2005 LC with 50mm OME lift (the front is closer to 60mm because I recently adjusted the coilover for leveling reasons)
I need to know if a differential drop kit will be necessary
If yes which one to get?
Thanks so much in advance
Not sure about your specific LC, but our 05 4R has a 3" lift and we did not do a diff drop. I was told it wasn't needed and it's been fine. Hope that helps!
-Daniel
2005 LC (US spec) is a 100 series, not a 120. May want to check elsewhere.
If it is a Prado (non-US 120 series LC) then you can lift without the diff drop.
