Diff oil to the stars...
Portland, Oregon
Decoding oil myth's,
When you live around only ****py auto parts stores getting stuff for my 76' 40 can be tough.
Question is: I want to buy the correct oil for my diff's(4.88's/ARB), Trans(stock 4-spd), T-Case(stock) and steering box(stock)
Below are the codes in repair manual.
-The recommended F/R diff oil is; Hypoy B / SAE 90 EP gear oil / API GL-5 SAE 90 weight gear oil.
-Trans/T-case; Hypoy, SAE 90 EP, API GL-4 SAE 90 weight
-Steering Box; SAE 90, API GL-4 SAE 90 weight
- What I want to know is with GL-5 Vs GL-4 in regards to will it hurt my trans/t-case to run GL-5(brass parts/synchros) Synthetic alternatives? 75W90 or....?
-Just looking for some old timers who remember when the same oil that went in their tractor also went into their cruiser and some fresh youngsters who run $10 a qt. synthetic and it's actually the correct stuff. What do you use?
-Cody
You'll get alot of opinions on fossil vs synthetic here.
Personally I use a blend of Mystic JT7 90w and about 25% of Lucas.
What's the difference?
Sigh. I guess I'm an old timer now. I'd put in the cheapest oil that was around 90w and change it once a decade or when it looks like green baby poop.
The GL rating goes from 1 to 5 with a 5 supposedly a more 'superior' oil...don't ask me to define that. You will be hard pressed to find in todays market an oil that what was called out in a manual for a 30+ year old design. Many including myself use whatever 80W90 is available at the local autoparts store. I buy it by the 5 gallon bucket for something like $30, IIRC.
The debate on whether one would be able to appreciate the extra cost of a $10/qt synthetic is unwinable. Believe me, many have tried. You could search and read for days coming to no conclusion other than many people have different opinions. Our old trucks are so forgivable you could probably run anything with lubricating ability short of ATF and probably not hurt them.
You are going to get a wide array of answers to your question, some that you may side with because it either fits your ideas and or budget.
There was a good debate on this very subject back in '07 by a thread started by Lee (Seaknight). Here is the link. Read and enjoy. https://forum.ih8mud.com/40-55-series-tech/143311-synthetics-tranny-t-case.html
-Cody
You can substitue GL5 for GL4 but not the other way around.
I run 75W90 GL5 full synth in my g/box and t/case no probs.
Some people report seal issues with synth oil but I think that's more in engines - have not had this problem myself...
Bob the oil guy
Bob Is The Oil Guy
This may not answer your question but it's a really interesting look at the perf of oils
