Diff Lock Normal Operation is what??
Chicago!
Hey all, just got a '97 450 with lockers. Tested them last night after reading the manual's not so good explanation of how they work...here's what happened.
Engaged rear only, light flashed and flashed...started moving the truck slowly and clicked in the front too and after about 1.5 city blocks of driving in a straight line it clicked in and the warning lamps went solid. Disengaged them, turned around and did it again. Could not get both to engage and gave up to head home.
The issue or concern I have is that it took a really long time to engage. I was anticipating it going in almost immediately. So what should I expect three minutes of waiting prior to engagement?
Thanks...did a quick search and did not find the right thread...which is not to say it's not out there!
And when when when will I stop being a rookie! :crybaby:
The locking sleeves usually require a difference in left/right wheel speed to engage....
Try driving in mud/gravel/snow/etc. while doing figure 8's and they should engage quickly :cool:
Don't engage them on asphalt as a locked diff will put major stress on your axles and drivetrain...
Ahh hah...thanks...and yeah I was on tarmac...driving straight not wanting to put any stress on the drivetrain. So then if you're standing still the diffs will never engage, some wheel movement has to occur huh?
Many do our Cable Locker conversion because:
(a) they put their elec. lock motor into 3 ft. of mud once too often---troublesome.
(b) they don't like the way Toyota has your locker working (i.e. not locking when desired, unlocking when not desired).
If the teeth on the sliding collar just happen to be aligned at the time, then yes they will engage even when standing still :cool:
However, this happens just once in a blue moon ;)
On my (new) 80, I could not get the rear locker to engage. Dirt, gravel, grass, I tried it all. Forwards, backwards, circles, figure eights, you name it.
This was at least half a dozen attempts.
Anyway, CJF suggested trying it on pavement. We got the rear to engage within a minute, first time out.
I would not be concerned about engaging the diffs periodically on pavement as long as you watch the drivetrain and aren't driving excessive speeds/distances.
It's mostly the front you don't want to lock on pavement. Locking + turning = potential breakage
Again, I did it some on pavement when I was breaking in my rear, but I disengaged the front when turning and only used it very short distances. As long as you're driving straight, there should be little to no drivetrain windup, and you shouldn't have any problems disengaging.
If you get too much windup, they'll make a very noticable ping when they disengage. One tip if you have windup to the point where you get the ping (or even when they won't disengage) is to backup with the locker switch off. This has always allowed the diff to disengage very quickly for me.
On both my 80's (now that the rear is functioning again) I can get the lockers to engage (front, center, or rear) at a stop most of the time. I've taken to (on my rig) engaging and disengaging all three periodically when I'm sitting and waiting (IE: filling up on gas), and especially the rear locker.
The rear seems to get sticky first, so even just engaging/disengaging the rear periodically should be fine. I wouldn't worry too much about the center/front.
I have zero problem with testing them on pavement, do it often. But it’s not the best, most consistent way if you suspect a problem. It’s difficult to get them to lock/unlock on pavement, especially if your new to their operation. In this case my favorite method is to jack up the rig, have a helper run the switch, turn one tire on the axle, turn the switch on, you should hear the actuator run, then the axle lock. Turn off the switch, the actuator will run again and the axle unlock. If it operates correctly in this test, your good to go.
The rear lock collar only has 5 teeth, this makes it require more differential rotation to lock, in the worst case about 20% of a tire rotation/slip. This design makes it difficult to lock when you don’t need it, like on flat ground, it has little/no effect if you need the locker. A locker is to stop differential tire slip, if you need the locker, 20% of a tire rotation/slip before it locks is a zero issue.
When I started wheeling the 80, would approach an obstacle, think I was going to need a locker, turn it on, watch, worry about the lights, run the entire obstacle, then switch off. Sometimes a light would still be flashing, never had enough wheel slip to lock it, in other words didn’t need the locker. Now I pretty much ignore the lights, identify the place(s) in the obstacle where a locker maybe needed, roll into the obstacle until I get to that spot or feel wheel slip, click the locker on, as the wheel clears the spot, click off.
As you get more seat time, become more comfortable with the locker system, you know whether the lockers are on by the feel, handling of the rig, the lights become a redundant distraction to what you should be paying attention to, driving.
I only know of 1 'Mud member that has installed a Downey cable locker on an 80 and he hates it. In fact, he has had an open offer for the last 4 or 5 years to swap it for a rear Toyota actuator. Nobody has taken him up on the offer. :)
Here is one of his posts detailing some of the mods he had to do to get the Downey Cable Locks to work.
Have you guys dramatically improved your product since Kurt bought his? Do you have one for the front?
-B-
You will stop being a rookie when you start getting better with searching. This topic has been covered about 100 times. I have personally covered the topic 10+ times with posts describing the testing procedure, posts with pictures of the internal locking mechanisms F&R so you can see exactly how it works, posts with diagrams from the NCF describing how the locks work, and just about anything you could possibly want to know about the Toyota diff locks. Advanced Search, 80-Section, Author=Beowulf, keywords: diff lock testing (or lots of other key words will work)
-B-
Thanks guys...I just wanted to make sure it worked and yeah...duh...I would never turn with lockers on on a dry, paved road, hell I wouldn't even turn on a dry paved road with the center diff locked unless I was testing a x-fer case's operation! But always better to be safe than sorry right? Read a few posts where people are doing not so smart stuff...like running their truck's out of oil...ouch!
Thanks a ton for the tips though guys, seems like the system is not perfect and for sure needs a better explanation in the manual. I'll be doing some driving on a sandy roads early next month and will engage/play with it more then.
And I'll do a search on your string using your suggestions Beowulf for what you've already written.
Thank-you thank-you thank-you again...ordered my supercharger today! So happy not to be working on the old Small Block powered FJ60! Guess I picked a bad handle tho huh?
