Diff lock light turned on while driving
Lahore
While driving home one day with same route and same traffic, all of a sudden the one diff lock light started blinking very fast and shortly turned off.
Again it come up in few seconds and then it never go till I reach home.
No any noise. No change in feeling while driving. No 4x4 engaged etc.
I am observing that LC is smooth as usually. But this diff lock light is not going.
Has it happened with someone else too?
What was the solution ?
Here is the photo
Just ignore the lamp light which is on since many week. Have consulted couple of auto electricians but they are failed to solve the issue.
Short? Looks like the front locker? Check the connections in the locker ecu in the PS kick panel? or the wiring leg from the FW in teh engine bay down to the loack and the lock sections as well? WAG
i had a look beneath at central 4x4 hub and saw some dangling wires over there.
don't want to connect these wires bymyself as i may connect them incorrectly.
so will visit auto electrician get it fix.
thank you for the support.
The lights are ground switched so if your connections aren't sealed and you are driving in rain or snow it can illuminate. Mine does all the time when wet, I just haven't mustered the energy to deal with it.
They only plug in one way, you cannot mess it up, and that is why you have a light on
not necessarily. There are many unused connectors in our wiring harnesses. The CDL is used on all of them as far as I know, so its either a compromised connection that is allowing the pin to ground out or a different type of short. If it was disconnected entirely its unlikely that the light would illuminate at all.
Its true that i see many un-used electrical connections too in the engine bay, around differentials and even i have some free or un-used electrical connection under my driving seat.
Seems the previous owner of this LC has pretty much messed up with it.
