Diff fluid? I smell it.
Southern California
I decided that I could tackle a brake change. This is what I found on the passenger side. Drivers side looked good. I can smell the diff fluid. I was apprehensive on starting a brake job now this.
Wife said " I need my car back in the garage ". I laughed, she laughed then I kicked the dog. Jk.
Guess I'll start reading. I'm kinda lost on where to start, what to get.
I knew this day would come. Just not now.
Looks (and smells) like you blew an outer axle seal. Not a big deal, but swapping it out is a messy, time consuming endeavor. Search for "knuckle rebuild" to see what's involved. You may as well swap bearings and gaskets while everything's apart.
Thank you. Reading faq now and compiling my list. Says to get a rebuild kit from Cruiser Dan. Is that still possible? Also it says to lock the front diff before I start. Can I still do that? The pic I posted is as far as I have dived in.
Thanks for your reply.
I rebuilt mine with the front unlocked since i was in the middle of an engine rebuild at the same time.
It was fine.
I've heard the rear on the other hand, you definitely want to lock.
Can I still lock it? I have it on stands all wheels off. Rear rotors and calipers off. I've only got as far as the pic shows on front.
What is the question?
What is a "brake change" (rotors and pads)?
Do you have a leak somewhere, birf soup dripping out of the knuckles???
The photo appears to show rusty wet stub shaft splines; have you driven
though deep water recently?
When I did my front axle I was intimidated but in all honesty it's a pretty easy job. Just long and messy.
You could probably look in the inspection hole on the knuckle to see if you actually have diff oil getting into the birfs before you pull everything apart.
Cruiser Dan retired.
Get your kit from Kurt at Cruiser Outfitters.
@cruiseroutfit
Looks like you may have moisture in your knuckles. Have you been driving through streams, puddles, lakes during a long day of wheeling? If so, you should always flush after water crossings.
pads and rotors. No birf soup. No recent water crossing. I could just smell diff fluid when I took the drive flange off.
The PO hasn't touched the birfs in 10 years.
But if you think I can just change the pads and rotors I'll definitely do that.
$200 + for rebuild kit.
Thank you
Yes. I am definitely going to check that.
Thank you.
I just completed this job, a full knuckle rebuild on both sides, a couple of hours ago ! Third time I’ve done it on two different 80’s in the past 10 years.
Advice:
Watch a YouTube video to understand the complexity and time frame. I watched OTRAMM’s series even though I’ve done it before; just reminds one what to look out for and it keeps the anxiety down.
Use nitrile gloves: I use Gloveworks HD black ones since it’s such a messy job. I went through two boxes but I’m a little OCD and change often. Buy more paper towel than you can imagine. I use ‘Scott Shop original’ blue towels. I went through 12 rolls. Buy brake cleaner, more than you can imagine. I went through 8 cans.
Take your time, label stuff if your first time, and take many photos to help you with the sequence of parts.
90% of this job is cleaning; kinda like painting 90% is prep. You will clean, and clean and clean some more.
It’s really not a technically hard job, it’s just time consuming. Watch the video often !!
Happy to answer any more questions you might have.....
You will feel like Superman when you are all done !
Advice:
Advice:
I just watched OTRAMM. Thank you so much. I'll hit you up if I have issues.
Still looks lubricated. Make sure your breather has flow, add some more grease to the knuckle and rebuild in the near future.
Yes check your breather tube - drivers side, hose running from axle to a frame mount. So long as the spring in the valve functions, use a degreaser to clear the tube till you can blow through it. Or replace the whole thing if you like. Or extend the hose to the firewall for regular deep water crossings.
CruiserOutfitters for the rebuild kit. $115 w/o wheel (hub) bearings. $200 or so with. Or NAPA has the Koyo wheel bearings if you want to walk in and buy. No major diff in price. Recommend checking your claw washers for wear (important for maintaining preload) and your knuckle stud bolts for strength. Neither come in the kit and are often quite worn or weakened from stress. I sheared one stud @~30ft/lbs (they should be @70+) and my claw washers were severely grooved. Good to replace them both (2x claw, 8x studs).
OTRAMM is an excellent resource. There are others too if you want a rounded idea of different approaches to the same work.
Like another poster said, the rusty shaft jizz is indicative of axle seals and possibly breather obstructions, especially if no history of being inside there for 10 years.
What color is your diff fluid now?
