Diff fluid? I smell it.
Yes check your breather tube - drivers side, hose running from axle to a frame mount. So long as the spring in the valve functions, use a degreaser to clear the tube till you can blow through it. Or replace the whole thing if you like. Or extend the hose to the firewall for regular deep water crossings.
CruiserOutfitters for the rebuild kit. $115 w/o wheel (hub) bearings. $200 or so with. Or NAPA has the Koyo wheel bearings if you want to walk in and buy. No major diff in price. Recommend checking your claw washers for wear (important for maintaining preload) and your knuckle stud bolts for strength. Neither come in the kit and are often quite worn or weakened from stress. I sheared one stud @~30ft/lbs (they should be @70+) and my claw washers were severely grooved. Good to replace them both (2x claw, 8x studs).
OTRAMM is an excellent resource. There are others too if you want a rounded idea of different approaches to the same work.
Like another poster said, the rusty shaft jizz is indicative of axle seals and possibly breather obstructions, especially if no history of being inside there for 10 years.
What color is your diff fluid now?
Thanks for your reply.
I changed the diff fluid about a year ago and it looked dark. But it didn't seem to be contaminated.
I'll look into new studs and washers. Unfortunately I am going to put the axle service on hold for a bit. I'm hoping to get to it in a few months depending on my work schedule.
