Diff capacity on a locked 80?
Front Range, Colorado
Just did the service and noted that both diffs took less than the capacity listed here on the forum. Filled on reasonably level ground. Front and rear both took appox 2.6 qt. IIRC, some say the locked 80s take a bit less, so maybe I'm okay. What do y'all think??
Edit: This was bugging the snot out of me so I checked my '97 FZJ80 and LX450 FSMs. My total gear oil usage now makes more sense :):
Front differential: pg SA-22
17. FILL DIFFERENTIAL WITH GEAR OIL
Torque: 49 N·m (500 kgf·cm, 39 ft·lbf)
Oil type: Hypoid gear oil API GL-5
Recommended oil viscosity:
Above -18°C (0°F) SAE 90
Below -18°C (0°F) SAE 80W-90 or 80W
Capacity:
w/o Differential lock: 2.80 liters (2.9 US qts, 2.5 Imp. qts)
w/ Differential lock: 2.65 liters (2.8 US qts, 2.3 Imp. qts)
Rear Differential: pg SA-76
16. FILL DIFFERENTIAL WITH GEAR OIL
Capacity: 3.25 liters (3.4 US qts, 2.9 Imp. qts)​
Transfer Case: pg TR-4
1. RAISE VEHICLE AND DRAIN TRANSFER OIL
Oil grade: API GL-4 or GL-5
Viscosity: SAE 75W-90
Capacity: 1.7 liters (1.8 US qts, 1.5 Imp. qts)
Torque: 37 N·m (380 kgf·cm, 27 ft·lbf)​
I just did my non-locked 80 and locked LX450 and the difference between the two in what they took is trivial. The FSM doesn't even reference a difference in the rear whether locked or not.
I followed the advice of my Toyota Master Tech friend and filled 'em up (on level ground) till gear oil started coming back out, put the plug back in with a new washer, torqued the plug down per spec, wiped everything clean, and called it good.
Unless you have a pump attached to a bottle with a known amount of gear oil in it, it is difficult to get too exact with how much you got in there.
If you are just pouring the stuff in from a 1 qt bottle (i.e. Mobil 1) it is impossible to squeeze all of the gear oil from a 1 qt bottle into the diffs, the front being the worst.
My approach...squeeze as much in as practical from the first bottle. Then drain the left over from the first bottle into another bottle while squeezing in another qts worth from another bottle. Repeat as necessary. In reality to do just one diff without the aid of a pump you really need 4 qts (front or rear) or some creative way to get enough of the gear oil from the bottle into the diffs. If you do both front and rear diffs at the same time you might be able to get away with 7 qts. Doing all three you'll probably want 9 or 10 qts on hand.
In all I used ~17.5 qts doing the front, center, and rear diffs on two rigs - one locked and one not.
The front and rear diffs take just under 3-qts each. The transfer case takes just under 2-qts. The difference between locked and non-locked is small (they are both in the 2.6 to 2.8-qts range).
Thanks for the confirmations guys! Since I filled until they were full, I though I was okay. Just surprised me that it didn't take more.
Again, thanks.
Diff Oils
I changed the oil in both locked diffs and the transfer case and used almost 5 litres. Had about a cup left over. The info in my Haines manual was wrong but I had just enough oil anyway.
Updated my post above with true FSM data which will hopefully aid others down the road searching for this information :cheers:
Sorry to wake this old thread...
But I just did a full front axle rebuild (knuckles) and left my dif draining for 2 days.
When I filled up it took 3.4 quarts.... and AllData also states this to be the correct amount of fluid, my LC is also locked..
Hmmm...
I was verifying posts on fluids when I came across this thread... I thought I might share.
I just did my front and rear diff service tonight. Will do the center tomorrow. The access to the front diff fill plug was bugging me b/c it was hard to squeeze from the gear oil container and not make a mess.
Went to wally world and found a funnel with about 1ft of clear flex tube attached ( $3 ) - then went to home depot and bought same size tubing about 3-4ft long. Attached the new tubing to the funnel - was then able to run the tubing up thru the engine bay and fill the funnel from the top! Much easier and wasted virtually zero gear oil.
On the rear I had to run the tubing out behind the rear wheel and fill the funnel from there. Again virtually zero spillage.
Capacity was right inline with what is listed above. I have pics of the process - I'll post tomorrow.
I used a pump that is readilly available at most auto parts stores... that screws right into the oil container... it will leave a little left on the bottom of the bottle but you just add it to the next bottle and so on...
http://www.softwaredesignspr.com/pics/4x4/pump.jpg
x2 on the pump shown above or something similar. Makes it easy to get to the t-case too.
Also, one trick I've learned is to place the bottles next to the fireplace or other heater. When the oil is cold, it can be difficult to pump, but when its warm it flows easily.
