Diff breather questions
I was under the 80 checking fluids and stuff.
Got to the rear diff and just as the fill plug loosened, air rushed out and so did a bunch of gear oil. So I immediately tightened the plug. So then I remove the diff breather and loosen the fill plug again, there's still gear oil rushing out! Next I pulled off the old hose and put on a fuel hose with no breather at all. Still I had gear oil gushing out.
With the new hose (and no breather) attached, I blew into and sucked on the hose. Blowing in resulted in oil gushing out. Sucking on the hose resulted in a vacuum and gear oil being drawn into the hose.
1) Could it have been a vacuum and as air rushed in, and gear oil spewed out to equalize the pressure?
2) Why didn't the removal of the breather (and hose) allow pressure to normalize?
3) Is there another valve located in the axle or possibly some type of filter?
4) Where does the breather assembly terminate?
I assume the breather terminates above the gear oil level or at device that does not allow gear oil to pass. Since it's a breather, I assume it's for air and not oil. But it's vary apparent that whatever or wherever my breather terminates, it's in the gear oil or below the gear oil level. I don't think overfilling the diff is an issue, since overfilling the diff is somewhat of an impossible task.
Easy big fella.
This sounds like your diff was simply overfilled. The stock breather is on the top of the axle housing and it is just a hose barb. On the end of the stock hose is a one way valve that lets air out but not in.
When you removed the filler, the pressure equalized. The excess gear oil ran out. That is all. No filters, no nothin'.
What many have done (myself included) is to use 1/4" fuel line and extend the axle breathers up into the engine compartment and eliminate the one way valve. I simply replaced mine with a lawnmower fuel filter. This eliminates the pressure build up as the diff heats and cools, allows the diff to vent properly, and keeps it high and dry for those occasional water crossings.
Good on you for doing things yourself. No better way to become intimate with your ride.
There is a great write-up on extending the diff breathers in the modification section of the FAQ.
I agree with Jon is that it was likely overfilled.
No need to extend your breathers unless you want to be able to do water crossings without fear of getting water in your diffs.
Easy big fella.
Do you really think this is possible. The fill quantity is roughly around 3 quarts, which corresponds to the fill hole. I don't see myself or anyone else being able to overfill by any measurable quantity. Especially any amount that should submerge the end of the breather assembly that terminates in the diff.
From previous posts, many members mention a vacuum. It's seems that there are two conditions that occurs in the diff. A vacuum and a high pressure condition. I'm not sure what the origins of such conditions are, but I think they're normal.
One of the reasons why I checked the diff's, is because I heard an abnormal, not the usual "whistle" while driving. With the breather hose and valve off and replaced with simply a hose, the "whistling" has gone away.
You heard whistling from the rear diff? While driving or you mean
after shutting down and getting under the truck?
I actually had forgot about the vacuum situation; was told
that about 20 years years ago as a potential problem area
on front diffs. The cure is to remove the breather and add
a longer hose like what you apparently did.
Interesting on that whistle; where did you hear it, under what
conditions?
g
I think the whistling was unrelated. No way there's enough air movement going on through a diff breather to cause a whistle while under way. No way.
DougM
Absolutely possible. Most service joints use a pump to push gear oil around. They will fill the diffs until it starts running out, but if the fill hose is large enough and the gear oil is under enough pressure theat diff will get over filled. Absolutely not a problem IMO. In fact I like to keep my diffs overfilled and have done so for many years. I drive the rear tires up ramps, fill the diff and transfer case, turn around and do the same to the front.
You'll always get gear oil in the breather regardless of how much oil is in the diff because it's sloshing around, covering all the spinny bits in delicious 90 weight. As the fluid starts to heat and air wants to escape through the breather, it's only logical to assume that gear oil will be pushed up the breather line. No big deal.
