No timing belt or chain and two items that need to be first verified: got spark and got fuel?Is there a timing chain?
A fairly easy way to check fuel pressure is to squeeze the fuel line hose under cylinder #1 while trying to start it. It should pulsate then firm up. The actual way to check fuel pressure would be to go to Autozone and rent (for free) a fuel line pressure tester. Remove the cold start injector line from where it exits the fuel rail and tap in your tester there. Fuel Pressure should be around 45 psi while cranking.
