Diagnosing electrical issue
reddog90
Houston, TX
I put my truck in reverse to park in my office garage today and it died. The starter cranks well, but it just will not start. My headlights, brake lights, hazard lights, and windshield wipers work. My gauge cluster, turn signals, and reverse lights do not work. My fusible link is fine. None of my fuses are blown, but I noticed someone along the way has swapped them all out for 30 amp fuses. I checked both sides of each fuse with a test light. #5, 6, and 7 do not light up, which are my heater, turn, and engine fuses. I confirmed I am not getting spark by pulling a plug, grounding it on the engine block and turning the key. Where would you guys suggest I look next? Thanks.
- TOW home ,
- un-do pos. battery cable terminal
- remove both 10mm hex bolts that hold fuse box in / on
- look at ALL 3 inline connectors for melting , Green , Black , White
- follow them to your electrical ignition switch
- peel away tape , and look for melted wires / Verify None are
after i read your description this was the first place i thought i would look 😕
lets hope im wrong
Look for the Brass Terminals Melted down at bottoms
@RAGINGMATT Terminals look fine to me?
Do you think this is the problem? Would the wrong size fuses have caused this? How far back in the harness do I need to trace these wires and splice in new? Thanks.
OH SH#T 😕
u still have My Shop Hotline RedDog ?
Call me now if u can , this is easier explained over a brief call
Oh s*** is right. You’ll be lucky if your harness isn’t toast. Often when the ammeter shorts it takes everything out with it. I’ve got a Christine story about the harness in my ‘68 somewhere on the forum.
If those heavy wires are only melted back so far then I would say a bad connection at the ammeter overheated and melted the wire. If they’re melted about the same throughout their length, then I’d say a short or major overload occurred somewhere else. If you think about it, those two ammeter wires can’t really be shorted to each other. They are both hot, positive 12v. You could connect them together on one of those ammeter terminals and all would be good except that the ammeter wouldn’t work. If good wire is not far away from that spot, then I think I’d have to just try it and splice in two new pieces with good new terminal ends and clean up the ammeter connection screws. Worth a try and I doubt you would cause any more damage.
The AMP Meter 2 Wires B+ Grounded out on the Body or Housing of the Cluster Meter witch is NEG -
( Most Likely )
Something Had To Give ? , or the 2 AMP Meter Wires would Keep On " Melt-0-Down "
and it was NOT the Fusible Link ....................
so assuming assuming the 2 AMP meter wires are Major Damage should be considered
@Coolerman 's time has come :)
Yup! Hard to tell with out more inspecting. It's the close up look that has me leaning towards a terminal failure on the green wire. Just playing detective and putting in my guess.
You need to check those two wires, from Alternator, to fusible link, to ammeter and to fuse box.
That will entail unwrapping the harness... at a minimum, every few feet.
I would pull the harness, unwrap it, inspect every inch if every wire and see what, besides those two wires, required fixing/replacement.
You’re very lucky your truck didn’t burn down.
That melting appears to be old, or you would have seen and smelled smoke when this last issue occurred.
The real issue? A short that pulled enough current to melt two 8 foot lengths of 10ga wire, will have melted other wires near them. This creates short circuits in the harness that the fusible link, nor the fuses in the panel, will protect you from. You have a fire waiting to happen!
Pull that harness and see how badly the harness is melted internally. Also replace all the fuses that are not the correct value BEFORE you try any repairs!!! I would remove the fusible link and replace it with a 10 amp fuse. Just use a couple of clip leads to attach it. That way if you try a bypass, and there are major shorts somewhere else, the small 10 amp fuse will blow long before anything else can heat enough to melt. Forgot to add that you should not try to power up a bunch of stuff with just the 10 amp fuse installed. It is there just to make sure the harness does not catch on fire if there are internal shorts...
s*** it is... been there, done that.
But you’ve got @Coolerman in your corner. He has everything you need.
It’s work, but you will learn a LOT about your electrical system.
I Love it 🤣
This is My Official Favorite Quote Of the Day & the Official IH8MUD one Too !
But you’ve got @Coolerman in your corner. He has everything you need. "
Simply Because its So True .............
2018226
Do you guys think I need to pull and open up the entire harness, or just the stretch following the two damaged wires?
Not to be flip... but, we’ve already said you need to pull it and thoroughly check it.
It’s a potential disaster waiting to happen!!
Mark is the true expert and here’s what he said, “Pull that harness and see how badly the harness is melted internally. Also replace all the fuses that are not the correct value BEFORE you try any repairs!!! I would remove the fusible link and replace it with a 10 amp fuse. Just use a couple of clip leads to attach it. That way if you try a bypass, and there are major shorts somewhere else, the small 10 amp fuse will blow long before anything else can heat enough to melt. Forgot to add that you should not try to power up a bunch of stuff with just the 10 amp fuse installed. It is there just to make sure the harness does not catch on fire if there are internal shorts...”.
I’d hate to see you burn your truck and, possibly, your house down...
It’s work, but it’s the safest way.
Man I was really hoping I could get away with opening up just the stretch along the two damaged wires and repairing while it's installed. I've done a lot to this truck but pulling the harness sounds pretty damn intimidating.
Take photos and label all connectors. It’s not that bad, and when you’re all done your harness will be much better off than it was before.
I’m pulling my harness for a second time in the next couple weeks... if I can do it, you can do it.
