Developing plan for new FJ40
Santa Rosa, CA
I've been lurking around learning what I can and this time when I signed on I was chided for not having posted anything - abuse from a computer!
My wife bought me a '66 FJ 40 out of Utah (we live in California). From inspection it has a 327 v8, saginaw PS conversion and some very fancy 6 way power seats. Stock tranny and Tcase. No spring over conversion. 33x12.50 tires.
I'm starting to make my list for this project and am trying to decide if I should just go ahead and swap the rear axel or keep it and work with the Tcase options that go with it.
This is our "spare" car so it needs to be drivable. I'd like to get better speed range out of it - a 5 speed like the NV4500 and I'd like to be able to take my son out 4 wheeling and rock crawling in a few years.
I've swapped axels before - it's not that expensive or complicated. And with the stock axels having 2 wheel cylinders and the difficulty I had getting those replace - I'm kind of halfway to putting a dana 60 in it already - are there issues I should be aware of?
The only real problem is once you change the axel you've got to change the Tcase at the same time - and probably the tranny too.
In the short term - I have no experience with the vaccum powered TCase - I don't want to have to dive into that thing and fix it - how tough is it to just convert it to a mechanical linkage like the Lokar.
Peter
It'd be much easier to go with cruiser axles from a later model, that way you get disc brakes for the front, and you can convert the rear to disc. Your ball and claw axles can't be converted easily. All your brake lines will have to be changed, but there's no need to change the transfer.
OK, I tried to post some pictures, we'll see if it works.
Peter
I would drive it some and decide what purpose it is going to have (wheeling, mild dirt roads, asphalt driver, daily driver, show truck), and that determines your mods
I've been driving it when weather permits. It's really fun to drive. This needs to be a drivable stree machine as it is our backup vehicle when one of our primary cars is in the shop. I'd like to some mild wheeling in the near future and probably some more aggressive wheeling in 5 years when my son is old enough.
Peter
Peter
In tech : http://www.ih8mud.com/cruisertech.php there is information about 60 swaps. Also using search for this as well as the change to mechanical from vacuum will help. There are several threads on the transfer change.
Welcome:flipoff2:
Nice cruiser! My 77 has a 350 and an nv4500 and can crawl or cruise at 75 mph. (I don't do much of either one). But more pics would be nice. Good Luck
Thanks for the link - loads of useful information. I found the article on the center diff rear ends, not sure I understood all of it but I'll digest it for a while. Couldn't find the article on converting the air driven tcase shift to mechanical - any idea what its called?
At 75 mph, you knees must get pretty hot.
Peter
Peter
Try here for a start: https://forum.ih8mud.com/showthread.php?t=4656&highlight=vacuum+mechanical+transfer+case and then run some thread searches with different terms, as you can see I did vacuum, mechanical, transfer and case.
Good luck!
