Great plug and cap kit with fast shipping. Thanks, Jim.![]()
The idler is only necessary when using a stock 79-87 Cruiser PS pump & bracket.Jim,
Ive got Mini Truck PS and removed smog components. Is your pulley necessary for my set up. Thanks in Advace...
Run a 3/8NPT tap in the hole, just enough to clear the threads.Any suggestions on how to clean up the threads in the thermostat housing?...looks like I’ve got some type of hard sealant left behind after removing the BVSVs.
Use regular teflon pipe dope, as intended for any interference thread in a liquid-tight application.Also, per this post, Jim recommends no sealant on the air rail plugs. How about the BVSV plugs, I presume something needs to be used to prevent a coolant leak?![]()
Nic, finishing the carb now. It was dirty and slightly bent, but no major problems.
Dissy tests OK, just needs recurved now.
It's simple. There is no gasket. There is an insulator w/ gasket permanently bonded in place. If the gasket is damaged, the correct repair is replace insulator.That would be great!
Can i just replace the gasket on the insulator without buying a insulator? Does the new gasket also have to be epoxied on?
My insulator plate gasket came off all messed up. So i will need a new gasket there as well as the other gasket.
Sorry for the 20 questions.....I have not seen a very good diagram of how all this goes back together gasket wise.
Thanks Jim!
