Sorry..late to the thread but Clay covered the bases pretty well. If you need any pics from underneath of the mounting points let me know or any other particulars just ask.
what i shoulda said was not ALL the holes,,, i drilled and tapped the extras needed for the bellhousing mounts and did not use the cross member mount.
Not to hijack but I just wanted to clarify. So you didn't put a crossmember on the rear of the tranny, just the front bell housing mounts? If that is the case did you ever have any issues with it?
toddslater said:Sorry..late to the thread but Clay covered the bases pretty well. If you need any pics from underneath of the mounting points let me know or any other particulars just ask.
The block has these huge mounts on the PS. Not even sure what mounts in that bracket. The DS looks to have your basic Cruiser mount.
Thanks again for all the help!!
RHINO said:awesome,,, pics with numbers
1 and 2 are your motor mounts for the frame, weld'em back on, dont know why the bell mounts arent there if he kept those.
3-4 are bell housing mounts
5-6 are motor mounts
8- crap, theyre the aftermarket ones anyway
7- good ones
i dont know about that big thing pretending to be a motor mount, prolly alt or smog pump mount with the AC up high, i'd replace it with the older one, but keep it just in case.
the second pic of the bell,,, loose that bracket #4 goes there.
I'll probably have to swap it. I believe there would be interference with the PS shock tower.PabloCruise said:A/C compressor mount - may come in handy if you ever want AC in the Pig!
Tim also gave me the frame mounts for the bell-housing he recently cut off his 55 frame, so I'm set there. I'm going to install the T/C rear cross-member as well (since I have it). I'll have to have some buckets fabbed for that.
So all I need is: 55 bell-housing mounts and rubber!!
TemeculaTim said:Reid- got something for you- trade for a few of my favorite brews![]()
I just got mounts and rubber yesterday. I greatly appreciate it however! I owe you the brew(s) anyway.![]()
I believe I have the short shaft WP.RHINO said:. . . you will need to use a short shaft water pump from an early 2F engine to clear the radiator.
