I am about to pull the engine and pulled the lower radiator hose and pipe earlier today and noticed a decent sized dent in it. Is this normal? See below for the part, item 16577. It was directly above the tubular frame brace.
I did a HG, PHH, bypass#1 and heater valve over the past year. I still had a slow leak that showed no signs other than dried antifreeze along bottom parts of the truck and monthly refills on my overflow. It kept me paranoid about the HG that now has 100K miles on it. after a year it finally got leaking bad enough to drop on the floor and I tracked it down to a hairline, but growing crack in the identical dent that you have. I tried welding it with oxy/acetyline and discovered it is stainless. I got it to seal but ordered a new one and have it on the shelf. Source of the dent was the autozone ( too long ) replacement hoses that forced the pipe down on the frame. If you have the same problem, trim the hoses to the right length to get them off the frame and watch that spot carefully. Probably wont have a blowout like a blown hose but you risk a slow leakdown of your coolant that you dont notice and risk an overheat. OEM part was surprisingly cheap... I think in the $30sI am about to pull the engine and pulled the lower radiator hose and pipe earlier today and noticed a decent sized dent in it. Is this normal? See below for the part, item 16577. It was directly above the tubular frame brace.
View attachment 1130327View attachment 1130328
