Deciding on Suspension Refresh
Virginia
I’m down in Charlottesville with a stock 87 FJ60. Next year’s project is a suspension refresh. I’ve looked heavily into Cruiser Outfitter’s OEM kit as well as Terrain Tamer’s parabolic kit.
Use is 100% road, and I don’t plan on rock crawling ever. My tires are new 31s. I mostly drive around town with some scenic drives, road trips thrown in. Really looking for input on whether lifting makes any sense, pros and cons etc.
Don’t add a lift if you don’t need to. Cruiser Outfitters are a great company to work with.
Peanut galley thought for your consideration ...
  • Getting your FJ60 weighed where you can share total empty weight plus the weight breakout on each axle. (a local feed store had the vehicle scale and a helpful attitude when they weighed my Cruiser)
  • Also if you might take your Cruiser on an extended trip loaded (family, camping equipment, luggage, ...), providing an estimated payload weight would be helpful.
  • This kind of info would help Kurt (Cruiser Outfitters) or Georg (Terrain Tamer) to identify suspension system options tailored to your 60.
Good luck
as stated if no off road use is in your future I would leave it stock. Unless you really like the look of one with a small lift and 33 ( which does look great ) ultimately if you do a lift you will be sacrificing ride quality
on one hand it sucks to have stock worn out springs and bushings and on the other it sucks to have too much lift and then want to run a bigger tire. 25 years ago I put emu heavy on my FJ60 and did not listen to a friend who said to stick to a 31. Wound up putting 33 inch swamper radials on it and the 3.70 gearing did not like it. You will need to regear if you want to run a bigger tire. One thing leads to another. Might be OK with 31's if you get some on the smaller side as a 33 inch swamper is on the bigger side of a 33 inch size.
Keep it stock!
i'll tell you what you want to hear. I don't know what's happened to this group here telling you to keep it stock looking like a station wagon.
Put a 2" lift on that sucker and make it look OEM+ you know you want to. It'll look so much better with a mild lift and 33s.
