Death Wobble, cannot track it down
Buckley, WA
Ok, so i've had Death Wobble ever since I bought my rig. I've read every post on here and contributed to many but still haven't found the answer to mine.
Mine happens between 40-50 mph and can get really violent as to where it feels like the axle is trying to jump out of the truck.
This is what i've done so far.
Rebuilt the front end when I first got it.
Replaced the front panhard with an a brand new adjustable one since a machine shop managed to break my old adjustable one.
Replaced front panhard bushings
Replaced tie rod and relay rod
Replaced TRE with circle 555's from Kurt
Replaced Radius Arm Bushings with 6 new OEM ones
Balanced my tires every way possible
Had cracks in the frame by the steering box welded and plated
Alignment done numerous times.
I've had now three sets of tires on here with two different wheels.
It was worse with my 16.5 wheels and I think that it was because they were re-centered so they were always a little out of balance.
With the new stock alloys and the xmls they are a lot smoother but I can still feel the steering wheel starting to rock a little although so far (5 days) it hasn't got really violent on me like it used to. This last weekend I also swapped on my buddies 33's to go with lighter tires and wheels and they acted just like the XMLS
The steering feels loose anyway so i'm thinking maybe the steering box needs to be rebuilt..... also is there anything in the actual steering shaft (from the steering wheel to the steering box) that might cause this? I did try tightening it up per land tanks instructions but it didn't seem to make a huge difference.
It's driving me crazy that i've replaced soo much and still have it.... although not as bad as it used to be.
I guess i'm going to get the 105 sceptor shaft and rebuild the box... maybe have it plumbed for hydro assist also.
I just want it to ride nice as my wife seems to want to drive it now but i'm afraid to let her till it is fixed.
I just had it aligned yesterday and will post up the numbers as soon as I get the paper out of my truck.
Any other ideas are appreciated.
Guess I should give my current suspension set up also
Slee 6 inch lift, everything adjustable with the Gen II arms not the current Gen III, 25mm coil spacers
I need the big brains here Slee, Tools, Land Tank, Dan, Beno to offer some suggestions up.
steering box is where i would put my money. was the vehicle ever in an accident that you know of?
front axle could be slightly bent. hairline cracks in the frame mounts(radius arm, panhard). bolt holes elongated...just brainstorming.
I assume you've torqued the knuckle bolts and they're not loose. How about your steering dampener? I had a bad one on a 4Runner cause death wobble. Different steering setup, but worth a look.
caster plates? with that amount of lift, what is your caster set at?
He has Slee arms, corrected for 6" of lift. Of course, he does have an extra inch of lift on top of that. I'm interested to see the numbers as well.
steering damper? ever had a look at it?
Rear driveshaft may be loose, have a look at that too.
I feel your pain. Death wobble is like cancer for a jeep, it may never be cured. Multiple Offroad and alignment shops could not resolve the problem.
Had the similar situation on my WJ grand Cherokee. Steering box was fine, then eventually died as a result of the repeated wobbles. Replaced everything (eventually). Finally eliminated with lift removal and a wj specific remedy. Things seemed fine for a few months, then a slight wobble exiting I-10 Took to another state and left it there.
Eliminating any slop in the steering will help, but may not fix.
Good luck with it.
It was before I got it but not sure as to what extent, i'll check that with the PO, I have checked for cracks but can't seem to find any but am going to check again at some point soon.. all the bolts seem to fit very snug in the holes.
I can't be more help here but does this death wobble happen all the time from 40-50, doesn't matter if you're on the gas or not?
It doesn't always happen, I can always feel the steering wheel start to rock slightly but doesn't always translate to the axle/wheels. When it does happen though it doesn't matter if i'm on the gas or not.
I have tourqued the knuckle bolts and I have new ones i'm going to install on my new axle housing that i'm going to install when I rebuild the axle again over winter.
Thought that there might be a slight bend or something so I procured a replacement one out of a low mileage one that suffered the cash for clunkers debacle.
I've thought about this but a bad steering damper couldn't cause death wobble just mask it better. I am going to be replacing my aging emu one with a new fox racing unit when they are released.
Here is the alignment info
mhhh looks like the caster and camber are out of spec.... I would have though it would be in spec due to the slee arms.
Whilst I know your axle has had a rebuild how long ago was this? Can you release the steering arms and check how much effort it takes to move the steering knuckles, use a spring gauge and shoot for the tighter side. I have seen axles rebuilt and the original shim/s put back on the top and lower trunions because the mechanic thought they had to go back, this often leads to the knuckle bearings not pre loaded into the tracks properly. With these a little on the loose side the steering/suspension can setup the death wobble but will not show up on an alignment machine, BTW I would check your OE alloys to ensure they are true as well, I do not mean balance but that they actually run straight on the machine, if you seem to have a lot of lead on one or more of your wheel this might be an indication something is not right?
regards
Dave
No personal experience with your setup, but it looks like you need to adjust those adjustable control arms. I believe most recommend getting the caster numbers up above 3° positive.
From Slee's website:
4. Caster:
By lifting the truck, the front axle moves away from the frame. Due to the design of the front control arms, the axle will tilt forward and reduce the caster angle. Stock caster for a 80 Series Land Cruiser is 2-4 degrees positive. It is our experience that you loose approximately 1 degree for every inch that you lift the truck. This is a rule of thumb based on caster measurements taken with different setups.
Note: We have since drawn the caster changes with lift out, and the changes are closer to about 1.7 degrees of change per 1" of lift.
the arms aren't adjustable, the adjustable ones are the rear arms.
The slee control arms are supposed to correct the caster for the lift that it is sold with.
So then, the adjustment would need to be accomplished via bushings or plates. Have you tried contacting Slee directly with this question?
I actually sent him a PM after I saw my numbers.
There shouldn't be a need for plates, or bushings though. The Slee arms are designed to put the caster back into operating range with the Slee 6" lift kit.
Hopefully he will post up and hopefully all I need is plates or bushings to remedy this, although I don't know why I would,.
