When diagnosing an engine that dies, remember that it only needs three things to run, Spark, Fuel and Compression. Since it is intermittant, you can pretty much rule out a compression problem. So next time it dies, pull off the air cleaner, look into the carb, grab the acellerator linkage, and "floor" it. You should see a squirt of fuel from the accelerator pump shooters. If the engine is warm, you'll see a puff of smoke as the fuel hits the warm manifold floor. If you don't see fuel, the carb isn't getting any. If that is so, crack the fuel line loose at the carb and look for some fuel to squirt out a little. The fuel line should have 3-6 psi or so of pressure. If none is there, you need to be thinking fuel pump, inline filter, clogged line, or plugged pickup in the tank. If there is some pressurized fuel in the line, you need to be thinking either the filter in the inlet of the carb (Q-jet or 2 bbl Rochester), or a sticking needle and seat in the carb. A good test is to give the carb a good smack with a wrench or something. That will dislodge the sticking needle causing it to start.
If you have fuel squirting, then it is time to look for spark. Take a spark plug wire off and insert a screwdriver into the end. Have someone crank the engine while holding the metal shaft of the screwdriver about 1/8" from something metal on the engine (safety note: dont hold it near the gas you just let out of the fuel line. Also, if you have to hold the screwdriver, dont touch the vehicle with any other part of you body, especially if you are leaning against the vehicle with you privates touching the fender!) If there is no spark and you have a GM HEI distributor, the the ignition modules are usaually the culprit, especially if it will restart after cooling off for awile. I've seen the pickup wires break internally on old, high milage units causing intermittant loss of spark too.
