Build Dave's 80
I have to care a little about mpgs. Even if it's just range I'm worried about.
The dog has as much interest in being hauled up a ladder as I have hauling him.
Ready for potts when you are...I think it opens 4/1?
Update time..
Built some drawers. I may have used too much...or not enough glue when applying the rubber mat to the top.
New oil level sensor gasket. One of the many leaks I noticed the last time I laid under it.
Sewed on a new gen you wine leather steering wheel cover. Had it in my parts pile for 4 years and thought that was long enough.
Bought the best winch very little money can buy.
Added to the HG PM parts pile.
I now need to get a rear bumper with swing out. I used to toss the spare in the back when I went wheeling, that's not really an option anymore. Also need stiffer/taller springs. Those drawers are heavy. The crap I put in them is even heavier.
More stuff for the HG PM parts pile:
Update/photo dump
Switched to OMEJ springs and long travel shocks
Got a slee transfer case skid. Of course I snapped all 3 bolts in the crossmember. I ended up drilling out the bolts and using longer ones. Probably not a good permanent solution but it works for now.
The morning after I finished installing the new lift, I went to the capitol land cruiser club's fall crawl. It was awesome obviously. The cruiser did great and Im pretty happy with the j springs, especially off-road. Only breakage was my center diff quit working and I had to stop at a car wash on the way home due to a serious mud related death wobble.
Fixed my center diff. It was the bulb, which I figured out after I replaced both the 4l and CDL position switchs.
I figured since I had my dash apart I'd fix my floppy ac vent with the bushings I got from outsane but I ham fisted it and broke my vent, badly. So.
Also replaced a bunch of other dash bulbs while I was there.
So..
I got some 37s. @H8 Roads sold me his maxis trepadors on 17x9 97s for cheap.
My original plan was to trim the flares and keep them but as soon as I started pulling them I realized they were all for s*** and barely hanging on for dear life. So I went flareless.
After I pulled the flares the rear bumper was next. That's when I found this hidden cancer.
Not sure how I'll go about fixing it yet. Maybe find a good rear quarter and weld it in or tub the back above the level of the rot. Idk.
I decided to diy my rear bumper and swing out. Just getting started but I'm happy with the progress so far. Pics to come.
@FMC80 I haven't moved the axles, but I did trim some of the rear of the front lower fender liner. I may end up getting some Delta VS control arms in the future but not sure yet.
I put 300miles on it last weekend and other than one of the wheels being a little bent and causing a slight wobble, I'm happy with the way it drives. I had to buy a 5th tire and rim anyway so that should fix the wobble and I'll try to bash the bent one back into shape (yay steel wheels!). Mountain climbs are quite a bit worse. I will either regear, turbo, both, or LS it to remedy that issue (not anytime soon).
Bumper stuff.
I have a super Cool bumper! I'm stoked how well this has come together. It's simple, strong, and high clearance. Eventually it will have a swing out tire carrier too. Or maybe not, I really like it the way it is now and hate to clutter it up with a bunch more tube but I also really want that giant tire out of the back.
Anyway, I cut the frame a little, made some brackets and drilled some holes for a few grade 8 bolts. I'll be using the OEM tow hooks for now but might cut them off in the future.
I can't claim this design as my own. I just stole a bunch off here and ig and mashed them together to my liking.
I also couldn't have gotten this done without help from @BlueCruiser84 who did a majority of the welding (95%)and @bkfj40 who let's us use his bender. Thanks guys
Took it to uwharrie ohv for the old north state cruiser clubs annual Carolina Relic Run. I drove the cruiser 240 miles each Way with no troubles even with the 37s and stock gears. I averaged a little over 11mpgs (which surprised me). We got turned around by lightning at the top of Daniel but otherwise we Did all the trails. The relic run is a great time. if you haven't been and are able, I'd definitely recommend it.
thank you @matzell for being a capable trail guide in his V8 40.
also.
I landed hard on my new bumper several times and much to my surprise, it didn't fall off. so that's good.
also, also,
I offered to sign my title over to the owner of that LN 105. He politely declined. :(
Bro! Looks like a GREAT time! Impressive picture of the fleet that attended too. Uwharrie is only 4 hours and change from me…maybe next year.
Anything new you ID’d on the rig that you want to adjust/fix/spend money on for no reason?
Put it on your calendar for next year. Worth it.
I need a front passenger spring retainer or maybe just a stock isolator because without any weight over there (I think) when wheeling the spring bangs all over the place and is pretty annoying.
Oh and maybe this:
Updates.
Went to coal miners classic cruisers (or something like that) in PA hosted by Gotham City cruisers. Awesome time.
Then I drove it to the Adirondacks in update NY less than 90 south of the Can. border to visit old friends. The truck did amazing even on the 700 miles trip back to VA. I did use quite a lot of gas.
Wheeled it a bunch more..
(Insert cool pics of me doing epic sh#t)
Parts:
Delta vs panhard correction bracket.
High quality item. Helped with the on-road manners a lot.
Slee Extended brake lines
No more using brake lines as limiting straps.
Prinsu rood rack
I broke 3 Yakima q towers in tight a$$ trails just this year and the last time I landed the truck on the awning (which took it like a champ btw). So I got this very expensive solution with quick detach awning mounts so I can leave it at home or camp when I wheel.
Semi annual update.
Went to potts. Didn't break anything. Potts is a good trial.
Went to the clcc fall crawl and snapped my front sway bar mount five minutes into the first hard trail on the first day. The mount flipped forward and took out my front pass hard brake line and lost all my fluid. Limped it back to camp and used one of those emergency brake line bolts from delta to get into town to buy parts. I don't recommend driving in traffic with only thee working brakes. I got a replacement line sort of and just pulled the sway bar off and was able to wheel the rest of the weekend.
I now carry a few different lengths of hard line and a bender with me.
Soon after my club started talking about a trip to Moab and I committed before I was sure the truck could make it.
I Spent the next 6ish months dumping time and money into getting the thing as ready as a 30 year old Toyota could be to drive across the country and back.
Partial list not in the correct order:
fuel filter
fuel pump
throttle cable
fuel pressure regulator
Fuel pressure relay
Efi relay
Air filter
Throttle body gasket
Intake tube
Blue fan clutch from land tank ( the rock auto aisin died).
Plus some other parts I'm forgetting.
I also pulled the entire intake and tb and cleaned them really well. All the little vacuum lines underneath were replaced with OEM. Plus a new eval vsv and check Valve because they failed testing.
I ditched the drawers and got an interior tire carrier. The drawers were too heavy and I was carrying too much crap in them.
I like this better, mostly. Keeps me from having to build a swing out and hang a bunch of weight back there and I lost about 200lbs.
I also regeared it with revolution 4:88's.
I had a lot of help from @matzell and @landshark9 with the swap. Thanks guys.
I put some TG chromoly axles in during the regear.
Also with @matzell help. I got rid of the old trepadors, which I loved, It was just time
5 new Maxxis RZR MT 37x12.5.
Then a couple weeks later I drove it to Moab with my gf and met up with @matzell @landshark9 @doseman and @Beach80. We all took different routes there. Some towed out one had his 80 shipped. I ultimately chose to drive out. We left VA and took route 40 most of the way and then zig zagged though 4 corners area before heading up to UT.
We didn't do any hard trials but they were challenging enough to be fun. I didn't want to trash the truck 2000 miles from home. On the way back we went to the tetons and then took 80 to MO and hit 70/64 from there.
The 80 was flawless apart from the rear passenger window jumping the track which I fixed in the middle of a parrie in western NE.
Added one of these 9pm the night before I left for Utah. Smashed the vent in the process. It's a grey one painted to match. I found the paint on here.
Got home from Utah and was invited to go to sas9 in Colorado and of course I said yes. I tried to finish the things I didn't get to do before Utah for the next cross country (almost) trip.
new rotors and pads from powerstop and a new oem rear driver side caliper because it was sticking occasionally.
Also new arp hub studs from trial gear in the back and front range in the front. I had to mix them because front range only had enough for the front in stock at the time. The front range ones don't stick out as much as the TG, but the TGs have a hex end for easy install. I'd still pick the front range if I was to do it again though. I also repacked the bearings, again.
I also adjusted the e brake while I was in there so it actually kinda holds now.
New oem reman alternator (not pictured) and new belts. During the trip to Utah my scan Guage started randomly reading wild voltages. Like from 12.6 to 15.5. I figured it was the voltage regulator so I stopped at a auto zone and got a Chinese alt and just held on to it just in case. It never died or did it again until after I got home so I returned the dura last and ordered and installed a Toyota. the voltage stayed consistent after that. Until the morning I left for Colorado 3 hrs into the drive. I thought it was the radio because when I turned it off it went away. that's not it. Doesn't seem to matter if it's on or off. So basically had no radio for a cross country trip for no reason. ,😕
Anyway I changed the oil and the air filter (again) and drove her 1900 to ouray Colorado.
Truck did fine other than the wonky voltage. We had a great time and I can't wait to go back.
