dash switches
I have installed my new guage cluster and am now working on the center section of the dash which is just a rectangular piece of alumnium to cover all the holes and clean things up. It will house 3 more autometers and i need a heater switch, headlight switch, wiper switch and hazard switch. Mine are functional but pretty chipped and beat up. I thought it would be cool to do some nice matching switches. anyone know of any that would work? I don't think i'd be able to wire up these controls with a simple rocker swtich, it would have to be 2 speed and 3 speed switches. thanks!!
www.waytekwire.com They sell the Carlington switches that are used in Marine apps. Exact switches that ARB uses for their ARB locker system.
The switches are available lit or not with your choice of gray,black or red actuators and red,green, or amber lights. They can be ganged together with a nice looking bezel they sell. I use these switches on the lighting systems I sell for Nissan trucks. Very good switch.
BTW these are the exact switches BlueSea sells as the Contura switch.
So those switches will replace all the crazy pull switches? And can they be incorporated into a painless wiring system?
They could replace the heater switch(s), wiper switch, and possibly the Hazard switch, but not the headlight switch without some 'extra' wiring. Easily used with the Painless wiring. All you have to do is crimp on normal female .250 push on terminals and push them on the back of the switch. Waytech also carries these cool connectors that the switch bodies plug into so you can unplug the switch from the wiring harness easily. Part # 44386 for the socket and mating terminals for 16-14 ga wire Part #31090
BTW these switchs will handle up to 10 amps directly so they can handle heavy loads like the heater with no problem.
Depending on how the 2 speed in the wipers is wired, you made need a wiper specific switch, if you want the park function to work. most wipers need power in the form of power on to low speed, power on to high speed, and power to park at off position.
those switches are cool but i don't think i can use them for my headlights and washer and hazard stuff. i see different street rod shops that sell switches for like $10-20 and the painless is like over $40. qualitity difference?
