ROTW D'Animal 1976 FJ 40
Decal
Along way from home!
Here is a pretty easy way to put holes in a plate for mounting a spare tire.
Use an old brake drum. Grab a few of those 5/16 Phillips head bolts you have been keeping for years but have not found a use for.
Hold the brake drum up and mark the holes. Drill a 5/16 hole and insert the Phillips head bolt. The head is approximately 1/2"
Clamp the brake drum on over the Phillips head.
Drill remaining holes.
The all line up as they should.
Sent from my iPhone using IH8MUD
New castle DE?! That's right down the street!
How thick is the plate you used for the tire mount? I have seen the suggestion of 3/8 and 1/2 inch. 1/2 inch seems like overkill when compared to the OEM plates. I'm at that stage now. Thanks, Jeff
I think I found my running problem that occurs after it gets hot.
The machine shop took a lot of material off already and it needs another .090" to clean this up.
They are not going to do it. I'm hoping that I can make a newer 2F 3 piece manifold work.
